how to check if fuel heater is working
Old Feb 1, 2010 | 03:04 PM
snakefarmer's Avatar
How do you check if the fuel heater is operating? What temp should it heat the fuel?
Old Feb 1, 2010 | 05:03 PM
plcnut's Avatar
The best way would be to find someone with a dc clampmeter to check the ampload, otherwise you can check the ohm reading by unplugging the wire connector and making sure that you get a resistance reading, then check for voltage on the wiring harness supplying power to it. I think I read somewhere that it has to below 40 deg. for the fuel heater to turn on, but someone that knows a little more about these can correct me.
Old Feb 1, 2010 | 06:18 PM
Dodgezilla's Avatar
I deleted my initial message. I was thinking grid heater.....
Old Feb 1, 2010 | 07:08 PM
AH64ID's Avatar
Fuel heater should operate when the fuel is between 45±8, and 75±8 (IIRC)..
Other than resistance or ammeter I am not sure. Maybe an IR gun on the inlet and outlet of the fuel canister when the fuel is known to be below 45*F
Old Feb 2, 2010 | 09:28 AM
Lost Lake's Avatar
How do you know all this stuff??? Must have a mind like a steel trap, and a perfect memory!! Glad you're on this forum!!!! THANKS!!!
Sleigher
May 4, 2017 02:12 PM
Ramrod90
Feb 3, 2009 07:39 AM
taildragger
Dec 4, 2006 10:00 AM
Crabjoe
Dec 27, 2005 07:24 PM
tool
Apr 11, 2004 05:51 PM
