how to adjust clutch pedel?
need to get pedel to release clutch closer to the floor, tried to get used it releasing up high since new, I just get not get used to it releasing so high.
any help out there. |
Hey welcome to DTR!!!
What year of truck do you have?? Fill out your signature with everything about your truck like mine is below |
I don't think you can adjust the clutch play. The 6 spd. has a hydraulic set up and its a sealed unit.
Hydraulic clutches are self adjusting, just as disc brakes are. There is only a free play adjustment (sometimes) and usually this shouldn't be touched as it is adjusted at time of manufacturing. Essentially as long as there is a small amount of freeplay in the clutch pedal then it is adjusted properly. If the clutch is taking up too high hen there may be a problem with the clutch...or it is just normal and you will need to just get used to it. Compare it with another similar truck and see how it fees. If it feels the same then yous is normal.
Clutch adjustment
Well I hope you don't have the moveing peddles and there moved all the way toward the driver.
