-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   High idle function, ..what wire. (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/high-idle-function-what-wire-189817/)
na4now Jan 30, 2008 08:40 PM
I know this topic has been posted many many times. Ive been searching, and reading so much, I have a headache.
I had the dealer enable my high idle, today, on my 04.5 six speed. I read one time (here), that there is a wire under the dash, for the clutch switch, that you simply ground. Thats it.
I cant find where I read that, now. All I can find, says I need to run a wire from #22 pin (plug b, I think), on the ecu and run it to ground.
Where is the wire under the dash????? Do you guys know what Im talking about????? The diesel tech at the dealer says I need to buy a kit. I KNOW thats not so.
....I think it was a green wire, btw.
no_6_oh_no Jan 30, 2008 08:45 PM
You need to get the wire with the pin from Cummins and insert it into pin 22 slot on the ECU B connector and ground it to the ECU mounting lug.
There is no wire under the dash on a manual that will activate the high idle. That wire gets added with the clutch switch kit your dealer was referring to.
na4now Jan 30, 2008 09:56 PM
Oh, I see.
Should I go to Cummins, or the dodge dealer?
Does the wire/pin have to be a certain one? Probably just that type of pin, ....huh?
no_6_oh_no Jan 30, 2008 10:17 PM
Originally Posted by na4now (Post 1920531)
Oh, I see.
Yep, its a special little guy. [laugh]
Go to Cummins, a dealer would not have the slightest idea what you need.
part number= #3164263. ECU wire.
PRO-NRA Jan 30, 2008 10:34 PM
PM me with your email and I'll send you written instruction with pics & P/N for the pigtail. I did this mod two months ago on my 06.
Festus Jan 31, 2008 06:47 PM
Yep, go to Cummins for that part and spend <$20. The dealer will want almost $400 for the clutch switch.
staarma Feb 1, 2008 09:39 AM
Here's a little more info for you.
http://i16.photobucket.com/albums/b6...ma/ECMpins.jpg
http://i16.photobucket.com/albums/b6...partnumber.jpg
bob4x4 Feb 1, 2008 08:38 PM
[laugh] Some do [coffee]
Bob
D-Roc Feb 1, 2008 10:10 PM
I think a Deutz connector will work as well.
Ramguy 05CTD Feb 2, 2008 11:23 AM
I ran my ecm wire to the parking brake wire. this way you can kinda disable the feature. Im not sure if it engages the PTO function and will show up with a scan tool.[redface]
na4now Feb 11, 2008 06:12 PM
Some someone tell me where I can buy this online? The Cummins dealer wants $14 + freight for it.
na4now Feb 11, 2008 11:13 PM
Please!
Festus Feb 12, 2008 05:35 AM
What's wrong with that? The part was $18+ up here and cost me probably over $10 in fuel to go pick it up. Still cheaper than than the almost $400 for a clutch switch from the dealer. Get it and run.
na4now Feb 12, 2008 06:17 AM
Id rather just have it sent to the house. Im very busy with work, and dont have time to drive all over town some more.
Please guys. I cant find one place to order it online. I need it now. I idle all the time!
staarma Feb 12, 2008 09:34 AM
Most online places want $13.94 plus shipping. Sorry.
