-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   Help---Dodge Ram CTD Engine Codes (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/help-dodge-ram-ctd-engine-codes-106327/)
vonzoog Jun 17, 2006 10:26 AM
My 2004 CTD is showing an engine code of P0868.
The list I have does not show this number. However the list I have was printed from a Durango. Are all DC products using the same codes? Would a Jeep Liberty, Dodge Ram, etc. be using the same codes?
Any info on this would be appreciated. And does anyone know what the P0868 means?
Thanks,
crobtex Jun 17, 2006 01:24 PM
Look here. It says it's something about trans fluid pressure low.
Artie04 Jun 17, 2006 03:50 PM
Here is what 04 Power Train Diag manual says about the code:
Symptom:
P0868-GOVERNOR PRESSURE SENSOR VOLTS TOO HI
When Monitored and Set Condition:
When Monitored: Continuously with the key on and the engine running.
Set Condition: This code will set when the voltage from the governor pressure sensor is
above 4.89 volts for 8.5 seconds.
POSSIBLE CAUSES
OTHER TRANSMISSION DTC’S PRESENT
PARK NEUTRAL DTC PRESENT
GOV PRESSURE SENSOR SIGNAL CIRCUIT OPEN
SENSOR GROUND CIRCUIT OPEN
GOV PRESS SENSOR SIGNAL CKT SHORT TO VOLTAGE
GOVERNOR PRESSURE SENSOR SIGNAL CIRCUIT SHORT TO OTHER CIRCUITS
GOV PRESS SENSOR SIGNAL CKT OPEN INSIDE TRANS
SENSOR GROUND CKT OPEN INSIDE TRANS
GOV PRESS SENSOR SIGNAL CKT SHORT TO VOLTAGE INSIDE TRANS
ENGINE CONTROL MODULE
INTERMITTENT WIRING AND CONNECTORS
