Help With Codes
what are codes
p0107 p0073 they are now reading on my truck they did not read that when i went to the dealer, and now they are on there. thanks, chris |
P0073 = Ambient Temperature Sensor High
P0107 = Manifold Absolute Pressure Sensor Low |
thanks.
chris |
I'll bet those codes showed up after you installed the Edge EZ. You must have started the truck with somthing not connected, it throws a code every time[laugh] [laugh]
If you want to get them reset free of charge, head to your local Auto Zone, they can read and reset them :D |
actually, there was not a code on the truck the entire time with an ez........... also, i pulled code on moday, and it was p0524 or something like tat, low oil pressure........
then last night after pickingup from the dealer, these two codes where present...so you i have no idea what might have changed things........ well, maybe when the tech was looking at the turbo, cuz i know he had the airbox off, and maybe the iat senser got hot . chris |
| All times are GMT -5. The time now is 08:23 AM. |
