have hose off of my rear axle dragging on the ground!
Old Feb 6, 2007 | 06:45 PM
rjm022's Avatar
walked out to my truck tonight (04.5) and see something laying on the ground. it is a hose!!! i drove home tonight with no driveability issues! the hose attaches to the driver side axle tube, right near the rear shock. the hose is about 2 feet long. the other end has a small white plastic fitting with a metal clip on the hose- which obviously clips onto something on my frame,etc-i hoping this is just the breather hose for the rear axle. am i correct??? need to go investigate further-but i wanted some input!
Old Feb 6, 2007 | 06:49 PM
DODGE4X4's Avatar
It is a breather. Just clip it back up high and don't worry about it.
Old Feb 6, 2007 | 06:50 PM
Tony T.'s Avatar
From what you described it sounds like the vent hose to me also. Make sure you get it back on tight this time, sure don't want any water in that rear end.
Tony
Old Feb 6, 2007 | 06:57 PM
RETOOC's Avatar
Yes that is the rear end breather hose. It usually follows your rear axle flexible brake hose up to the inside of the frame and is fastened there by a clip. If the clip is rusted or broken you can fasten the hose up there with a nylon wiring harness tie. Check the metal cap and make sure it is free turning & not clogged with dirt, if it gets plugged up it can cause the differential to build pressure inside and force the pinion seal or axle seals to leak.
You can also fasten it to the brake hose for better reliability at staying in place.
retooc
Old Feb 6, 2007 | 07:04 PM
rjm022's Avatar
thanks-thought that was it! minus 6 degrees with the wind chill- can not find where it technically clips too right now- i cabled tied it up as high as i could. will have to route it better tomorrow! thanks.
Old Feb 6, 2007 | 08:34 PM
Need95-00CTD's Avatar
Yeah, make sure you cable tie it with a little slack in it, otherwise at full droop your likely to rip it out of the axle tube... Gear oil and Water don't make a good lubricant together, ask anybody who has sunk a Nissan axle in water, they'll tell you how much damage it can cause.
Old Feb 6, 2007 | 09:33 PM
VaultRam's Avatar
When I changed the shocks I clipped my breather hose to the top drivers side shock mount...works great!
Old Dec 5, 2010 | 09:05 PM
anpconnors's Avatar
Anyone have info on cap @end of hose?
Just ran 850 miles and discovered the vent hose on the ground. Do not have access to manual. Is there a cap at the end? If so does anyone have a picture or Part number? Thanks!
Just had shocks replaced and suspect the mount rusted and got hit during the R&R.
Old Dec 5, 2010 | 09:40 PM
kry226's Avatar
See the attached PDF. This is from the 04 catalog, but the axles are the same, and a vent is a vent.
Attached Thumbnails have hose off of my rear axle dragging on the ground!-2004-dr-ram-truck-part-catalog-76.jpg
moneytlks01
Jul 21, 2011 09:43 PM
Tallguy67
Dec 30, 2010 03:49 PM
ryan_289
Dec 4, 2009 07:56 PM
Keyser
Oct 22, 2009 12:43 AM
Dec 29, 2002 08:33 AM
