Gino's Garage Parts
Old 01-12-2019, 07:52 AM
AUGIE DOG's Avatar
Gino's Garage Parts
I need a new thermostat on my 07 5.9 and have been told multiple times DO NOT USE AFTER MARKET THERMOSTAT! Well Geno's has a Gates t-stat for $16+ but it's not an OEM Cummins part. Has anyone used this t-stat and is it equal to OEM?
AUGIE DOG is offline
Old 01-12-2019, 03:08 PM
Received 1,249 Likes on 857 Posts
I wouldn't use an aftermarket t stat. In the first gen series 5.9, The Cummins t stat is redesigned with two poppet valves in it because of cavitation and air bound issues. Check with Cummins regarding the 3rd gen having the same issue,or not.
It lasts years longer than the chino market ones.
Edit: they're called jiggle pins, not poppet valves.
NJTman is offline
Old 01-12-2019, 05:24 PM
Spooler's Avatar
Stick with the Cummins one.
Spooler is offline
Old 01-13-2019, 10:22 AM
KATOOM's Avatar
This is a well discussed topic... Some say the only thermostat worth having is the OEM one. Some say that they're not worth the high price for OEM and the cheaper parts store versions work fine. That said, I have a NAPA thermostat. Its been in there so long that I cant remember what brand it was either. But I do know that it works perfect and has the jiggle pins...and thats the part you want to be sure of. The Cummins engine needs those jiggle pins.
Other than that, Geno's Garage is a great company and they stand behind their products. If I had to replace my thermostat again I would not have a problem trying their much less expensive thermostat, or simply getting one from NAPA again. Its up to you...
KATOOM is offline
nbaggett89
12-26-2015 09:36 AM
greenworks
ABDTR #5
11-10-2009 08:03 PM
pwrtripls1
12-15-2008 02:23 PM
swmnkdinthervr
10-17-2008 08:15 PM
CTD_Neil
07-19-2005 08:13 PM
Quick Reply: Gino's Garage Parts
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
