gear vendors overdrive is in
Old Mar 28, 2007 | 12:35 PM
  #46
marathon's Avatar
GV Modifications
I'm interested in doing the install myself, but I read somewhere that installing a gear vendors on the short bed requires some adjustment to the fuel tank to get it to fit. Anybody got any info?
Old Mar 28, 2007 | 06:06 PM
  #47
mitternocht's Avatar
From Marathon:
Negative: All you have to do is shorten the drive-shaft.
Old Mar 29, 2007 | 01:34 PM
  #48
willmc's Avatar
Ordered
Gear Vendors ordered. Looking forward to better mileage!
Old Mar 30, 2007 | 05:23 PM
  #49
Let us know how you make out or if you have any problems questions. I wouldn't go with out mine now.
Old Mar 30, 2007 | 11:14 PM
  #50
bigjohn04's Avatar
Just wandering has anyone seen what the top speed is with the Gear Vendors, on a "track" of coarse?
Old Mar 31, 2007 | 12:03 AM
  #51
Jim O's Avatar
Hey Marathon! sorry for not getting back to you but I am on my way back to Canada and I have not been able to check my email. As others have said there is not any conflict with the fuel tank on a short box. just shorten the drive shaft. I believe you will love it when you get it installed I know I would not be without mine. I just read some posts that were made since I made my last one on this thread and I just want to say that Gear vendors do recommend the unit for towing behind both automatic and standard they also recommend for heavy towing with std. transmissions to put the trans in direct (fifth gear) and the GV in Overdrive this will reduce the trans temp by as much as 100 degrees f also sixth gear is the weakest gear in the trans so why not let the Gv do the work. Today I towed from Carson City Nv. to Winnemucca Nv and I was in double OD about 50% of the time. One thing I would recommend is a Pyro because if you are towing heavy even a slight grade if it is long enough will cause the exhaust temp to go high and my engine is not chipped. Double Overdrive is best used for bobtailing down the freeway.
Jim O
Old Apr 2, 2007 | 10:38 PM
  #52
joshua smith's Avatar
i have a 97 with one in and i have about 25,000 miles on it and i would not trade it for the world . i have 4:10 gears in the truck and it pulls at 75 like no other. no down shifting or nothin. dropped my rps by about 500. got 4-5 miles to the gallon better best invention for those who want to pull AND get mileage. i dont know of anyone else in eastern idaho with one
1997 cummins 235,000 miles,gear vendors 8 speed overdrive,stage 5 tst fuel plate, 4"exhuast, 370 injectors, full DTT trans, turbo silencer MIA, X-monitor, 4:10 gears w/limited slip, STOCK turbo
2004.5 cummins stock for now
Old Apr 3, 2007 | 11:27 AM
  #53
TonyB's Avatar
Originally Posted by joshua smith
i have a 97 with one in and i have about 25,000 miles on it and i would not trade it for the world...got 4-5 miles to the gallon better best invention for those who want to pull AND get mileage. i dont know of anyone else in eastern idaho with one
So, what is your mpg now, 26-27? I'm trying to gauge what my '06 improvement might be.
Thanks!
Tony
Old Apr 3, 2007 | 09:29 PM
  #54
i am averaging about 24-25 miles per gallon now. i was getting 20 usually, but that was at 70 mph, at 75 i was getting about 17.5, so it actually gave me about 6-8 mpg more. but i have 4:10 gears. with the gear vendors locked in i am doing about 1800 rpm at 75. it pulls great expecially with my setup. i nistalled it myself, took about 4 hours to get it in and wired. easy thing to do. had to take the driveline to get it shortened but thats it. simple to do though!
1997 cummins 235,000 miles, gear vendors 8 speed overdrive, stage 5 TST fuel plate, 4" exhaust, 370 injectors, full DTT trans, turbo silencer MIA, X-monitor, 4:10 gears w/limited slip, STOCK turbo
Old Apr 3, 2007 | 10:01 PM
  #55
DiEseLjunKy's Avatar
Yeah but you're getting 24-25 mpg on a 2nd gen. I might be wrong but Tony's probably gonna be dissappointed if he expects those kind of #s from a 3rd gen. I'll have mine towards the end of the month and will see. I would like to get 24 mpg but I just dont see it happening. Really the only thing I wanted from this unit was to the lower rpms and over the long term that can't be anything but good for my truck. It will be nice to run 75 mph down the interstate at roughly the same rpms as I'm turning now at about 63 mph or so.
Old Apr 3, 2007 | 10:17 PM
  #56
i have a 2004.5 stock CTD and if i can round up enough money i will put one in there too. im getting 18 mpg empty, NOT going by the overhead monitor and if i can get 22-24 withit in there, i will be pleased. either way, lower trans temp, better mieage, and less rpms is all i can ask for. i have 3:73 gears in the 04.5
1997 cummins 235,000 miles,gear vendors 8 speed, stage 5 TST fuel plate, 370 injectors, full DTT trans, turbo silencer MIA, X-monitor, 4:10 gears w/ limited slip, STOCK turbo
2004.5 CTD stock for now
Old Apr 4, 2007 | 02:32 PM
  #57
willmc's Avatar
Arrived today
Dealer said mine arrived today. Dropping the truck off this evening and picking up on friday. 200 mile trip on Sunday. Will post results here.
Old Apr 4, 2007 | 08:04 PM
  #58
TonyB's Avatar
Nah, I'm just trying to gauge it. IF I can get a 20% improvement, the payback might be there. I'd REALLY like to hear about results from 3rd gen owners. Not that I don't like hearing from the 1st and 2nd gen owners, but something that really applies to '04.5-'06.
Thanks fellas! Keep the info coming!
Tony
Old Apr 5, 2007 | 10:17 AM
  #59
JohnInNH's Avatar
2006 g56 HERE...
A SOLID 3 MPG on the highway. Won't really help around town. It lets you go 70 MPH If you are in a state with 70 MPH speed limit you will be able to keep up with the 75 MPH flow w/o guzzling fuel.
Towing you have 5th and 5th over... that's a big help. 5th over = 6th.
6th over is amazing empty. You will have a "go fast" truck.
When fuel hits $3 or even $4 shortly the pay back is sooner. At $3 gal it's a 3 year break even for me.
Old Apr 5, 2007 | 12:50 PM
  #60
mj007's Avatar
Originally Posted by JohnInNH
2006 g56 HERE...
So how darned fast will it go in 6th over? Will the CTD pull to redline in 6th & over?
