Funny Smell
Funny Smell
This is my first post. I read quite a bit of the post on the site. Figured you are the folks to ask. I have noticed over the past couple of weeks a funny smell coming from under the hood. It is not an alarming buring smell, just smells different. i checked everything i could think of. No oil or any other fluid leaking, exhaust looks, and sounds snug. I checked brakes and tires look fine. My fear is that something wore out inside the motor and I am getting the smell from something I can't see. No codes, overheating, failures, just a wierd smell. Also, it has been pretty hot
(100+/-) here in New Mexico recently, maybe that has something to do with it. Thanks for any tips.
2004 Dodge 2500 Cummins HO
Thanks. I checked those. Battery is good and Antifreeze level stays the same. I was poking around a little more on the site. I found an article that talks about a smell after the oil change. The smell did start after my last oil change. I had always had a local place change the oil (just was easier for me), I changed it the last time and used Shell Rot. oil. Quacker State had always been used before. Could this be the culprit?
That would probably be it...
http://dodgeram.info/tsb/2000/09-02-00.htm
or
https://www.dieseltruckresource.com/...=rotella+smell
or
Road Traveler
Jun 24, 2007 09:35 AM
steelsoldiers
Sep 15, 2003 08:01 PM
2nGlenn
Mar 11, 2003 01:51 PM
