fuel pressure gauage acting weird
Old Mar 15, 2008 | 09:25 AM
stacked07's Avatar
Di pricol gauge acting weird sometimes at idle it is at 15 sometimes 17 mostly and other times at 20 psi but sometimes it will be at 20 drop to 15 reel quick then back to 20 what gives have checked all wiring
Old Mar 15, 2008 | 10:53 AM
DiezelSmoke's Avatar
Typical reading for stock lift pump, sometimes you can get the dealer to replace it.
Old Mar 16, 2008 | 10:46 AM
stacked07's Avatar
not running stock liftpump running airdog 150
Old Mar 16, 2008 | 11:55 AM
snoyes's Avatar
Seems like stock PSI is around 11 PSI so you airdog is definately adding some pressure. Do you have the electric of mechanical FP guage? My electric autometer does jump around a little, but not 5 PSI. More like 1 PSI. Also, if it is an electric, they make a "snubber" that helps even out these fluctuations and supposedly extend the life of the gauge....
Old Mar 16, 2008 | 12:44 PM
Fisherguy's Avatar
(A stock pump is only 8 PSI BTW.)
Is the gauge mechanical with an isolator? Isolators have been know to cause lotsa grief...
Old Mar 16, 2008 | 02:13 PM
snoyes's Avatar
Read that guys have gotten 9-10 PSI for stock fuel pressures at idle, with the average is around 8 PSI. So, do you have documentation showing the the stock pump can only be 8 PSI max? Seems alot of gauges are going to be "off" here on this website.
Old Mar 16, 2008 | 02:24 PM
Fisherguy's Avatar
No, just what my gauge and lotsa other people's are telling us...
Whatever the case it's not enough if you run any kinda chip or programmer...
(AD-150 coming soon)
Old Mar 16, 2008 | 03:10 PM
stacked07's Avatar
I quess I am used to seeing higher pressure like on my 2nd gen but as long as it isnt to low and it is an electric dipricol
DHT
Jan 1, 2012 10:13 PM
nvr-enuf
Apr 22, 2010 12:50 PM
nasty01cummims
16
Apr 21, 2009 09:11 AM
chali84
Feb 15, 2009 02:45 PM
greenworks
Dec 1, 2005 11:38 PM
