Front lower shock bolt spinning help!
Old May 26, 2015 | 02:53 PM
robby t's Avatar
hi...I tried to remove the passenger side lower shock bolt well it broke free & now just spins..the flag nut broke and I can get the bolt out tried open end wrench inside the coil no room not sure of the size of the nut...not sure what to do.....anybody ever had this problem
Old May 27, 2015 | 02:23 AM
FastTaco's Avatar
Wedge a big flat screwdriver against it and hit the bolt with a impact.
Old May 27, 2015 | 07:41 AM
Jeff in TD's Avatar
Yeah I was going to say I've not had that happen, but maybe some penetrating oil, try to wedge a chisel or something in there, and try an air impact hammer.
Old May 27, 2015 | 10:04 AM
j's Avatar
j
Yup... wedge anything you can in there and create pressure, then hit with an impact gun
Old May 28, 2015 | 01:24 AM
robby t's Avatar
thanks to you DTR members that replied...well I finally got the lower shock bolt out! It took 3hrs. to do it. After lots of effort almost impossible to get a wrench on the silly mopar flag nut but I was able to wedge a pry bar to hold a box wrench that I had to heat up with map gas to straighten the wrench so it would fit between the coil & shock. My buddy held the pry bar & box wrench & I put the breaker bar & 21mm socket on the bolt & started to loosen it. It was super hard even with a length of pipe on the bar.. then voila!! the frickin 14mm bolt snapped ...yes!!!! thanks dodge for this screwy set up. One bolt three hrs....
Old May 28, 2015 | 07:56 AM
truckbouy2's Avatar
From: Frozen Northern Minnesota, Darn Close To Where Perma-Frost Begins...
Anti-Sieze on it when you put it back together. Everytime I loosen a bolt or screw on these rust buckets anti-seize is the answer for future repairs, AND there will be repairs.
rammv
0
Jun 28, 2014 04:04 PM
FordTrax
Apr 18, 2014 08:47 PM
xb9rumble
Jun 28, 2009 08:50 AM
CTD2001
Sep 24, 2008 08:54 AM
broncobilly
Apr 18, 2007 07:45 PM
