Front axle U-Joint replacement
Can someone please direct me to any thread that lists the sequence for R&R of the front u-joints in my 2006 3500 4x4 Dodge Ram Dually? Thanks, Dan H
https://www.dieseltruckresource.com/...+joint+replace
This has all the info you need to know! Not too hard, just be careful pulling your bearings not to damage them. |
Originally Posted by alltimelow1
(Post 2741838)
Well that thread you need to follow up to pressing the ball joints out if not doing ball joints. At that point just replace the front u joints as you would any other u joint.
(Post 2741838)
no no no no..... my u joints came out so hard i couldnt believe it. i had to buy three of them cuz i broke one putting it in they were extremely tight so get your torch ready
Mine were very tight also use a lot of PB Blaster I've done them with a old socket and a BFH and a ball joint press was easier.
Are the front axle u-joints plastic bedded like the drive shaft u-joints?
If they are, you need to heat up the metal to melt the plastic to remove them. |
Originally Posted by rbertalotto
(Post 2745612)
If they are, you need to heat up the metal to melt the plastic to remove them. Axleshaft u-joints are not plastic bedded. Just used lots of penatrating spray. |
| All times are GMT -5. The time now is 06:01 AM. |
