Flashes Needed On ALL '06 Trucks?
Old Jan 3, 2007 | 11:48 AM
jrussell's Avatar
Do all new trucks need the latest flashes or is there a cut-off point on the manufacturing dates? Mine was built in June, 06 and I just recently had my first long crank/hard start.
I was really trying to avoid having the dealer re-flash my truck until I got to know it a little better (and maybe never if it didn't have any problems).
Old Jan 3, 2007 | 03:37 PM
53 willys's Avatar
I had mine flashed in Sep-Oct? and I love it. I was having frequent hard starts but mine is a G56 trans, I did not think the auto's where having the problem?
the only thing I herd bad about any new flash was the back-up horn flash. I asked my dealer about it he said it was for the older auto's (04-05)???
just tell them not to do the back-up flash.
Old Jan 3, 2007 | 05:09 PM
isbeinside's Avatar
fto know the answer to that you need to know the ECM part number and check it for updates, you need a starscan or mobile and a dealership. i dont know if you can check the ECM with a downloader or equiv.
Old Jan 4, 2007 | 07:58 AM
Turbobob's Avatar
Not to hi jack...but my 06 with the auto has experienced the hard start issue as well. Long crank with a puff of white smoke. Hasn't happend to often, just a few times.
Old Jan 4, 2007 | 10:46 AM
53 willys's Avatar
take it in you wont be sorry.
nothing worse then a long hard starting cummins (it should fire on the first crank) makes me feel like I am driving a ford!!!
I'm glad I had mine done.
Old Jan 7, 2007 | 09:06 PM
egavas's Avatar
I have a question what does flashing mean?
Old Jan 7, 2007 | 11:19 PM
53 willys's Avatar
the dealer reprograms the trucks ECM/computer to fix problems and issues.
Old Jan 7, 2007 | 11:23 PM
jawsman@sbcglob's Avatar
flashing
my 06 auto was smoking under hard throttle and was geting bad milage
around 12, did not have the hard starting prob. now runs perfect after reflash back up to 20+mpg
Old Jan 7, 2007 | 11:47 PM
egavas's Avatar
Thank you for the information.
Old Jan 8, 2007 | 12:37 PM
steelblitzkrieg's Avatar
DTR Detective
November 9th 2005 is the cut off IIRC.
Old Jan 8, 2007 | 12:45 PM
jrussell's Avatar
But haven't there also been numerous updates since then?
Old Jan 10, 2007 | 04:46 PM
LFD2037's Avatar
There has been, even more recent then what the dodge info. site says. Last one for this came out Sept. '06 & is for the auto's as well as manuels. HTH
Old Jan 10, 2007 | 07:18 PM
Nav's Avatar
Nav
I had the Flash done for the hard starting and it didn't really do much. It still takes 2 cranks to start. Kind of embarrassing, but you get used to it. Of course, when you're at the dealer, it fires right up the first time, everytime
Where is the Dodge info site you speak of? I've been to the one at Geno's that lists all the TSB's but I haven't seen the latest flash fix.
Thanks,
Nav
Old Jan 13, 2007 | 11:31 AM
LFD2037's Avatar
The one thru Geno's is the one I'm talking about.
stidwell
Apr 22, 2008 09:35 PM
PurNLoud
Feb 6, 2006 08:47 PM
BamBam
Feb 19, 2003 01:21 PM
tobyw
Nov 13, 2002 09:11 PM
