DTC code PO513 What is it???
Old Dec 25, 2006 | 10:20 PM
SwingingCCattle's Avatar
My 06 Wont start and check DTC shows PO336 and PO513???
Old Dec 25, 2006 | 10:57 PM
dodgezilla04's Avatar
use the search feature, it may be faster for you sometimes. 513 is an invalid key code, sometimes caused by a downloader, sometimes false.
336 is crankshaft position sensor.
so, what have you been playing with on that truck? you can share here. anyway here is the list of codes from a previous thread.
What are the fault codes for my ODBII equipped vehicle?
Answer: P0016 Crankshaft/Camshaft Timing Misalignment/Out-of-Sync
P0071 Ambient Temperature Sensor Performance / Rationality
P0072 Ambient Temperature Sensor Low
P0073 Ambient Temperature Sensor High
P0088 Fuel Rail Pressure Too High
P0106 Manifold Absolute Pressure Sensor Performance / Rationality
P0107 Manifold Absolute Pressure Sensor Low
P0108 Manifold Absolute Pressure Sensor High
P0111 Intake Air / Charge Temperature Sensor Performance / Rationality
P0112 Intake Air / Charge Temperature Sensor Low
P0113 Intake Air / Charge Temperature Sensor High
P0116 Engine Coolant Temperature Sensor Performance / Rationality
P0117 Engine Coolant Temperature Sensor Low
P0118 Engine Coolant Temperature Sensor High
P0128 Cooling System Error / Thermostat Rationality
P0148 Fuel Delivery Error
P0169 Water-in-Fuel Detected For Too Long
P0192 Fuel Rail Pressure Sensor Low
P0193 Fuel Rail Pressure Sensor High
P0201 Fuel Injector 1 Circuit
P0202 Fuel Injector 2 Circuit
P0203 Fuel Injector 3 Circuit
P0204 Fuel Injector 4 Circuit
P0205 Fuel Injector 5 Circuit
P0206 Fuel Injector 6 Circuit
P0217 Coolant Temperature Too High
P0219 Engine Overspeed
P0234 Turbocharger Overboost Condition
P0236 Turbocharger Boost Pressure Sensor Performance / Rationality
P0237 Turbocharger Boost Pressure Sensor Low
P0238 Turbocharger Boost Pressure Sensor High
P0251 Injection Pump Fuel Valve Feedback
P0300 Multiple Cylinder Misfire
P0301 Cylinder 1 Misfire
P0302 Cylinder 2 Misfire
P0303 Cylinder 3 Misfire
P0304 Cylinder 4 Misfire
P0305 Cylinder 5 Misfire
P0306 Cylinder 6 Misfire
P0335 Crankshaft Position Sensor Circuit
P0336 Crankshaft Position Sensor Performance
P0337 Crankshaft Position Sensor Circuit Low
P0338 Crankshaft Position Sensor Circuit High
P0340 Camshaft Position Sensor Circuit
P0341 Camshaft Position Sensor Performance / Rationality
P0381 Wait-to-Start Lamp Inoperative
P0461 Fuel Level Sensor 1 Performance / Rationality
P0462 Fuel Level Sensor 1 Low
P0463 Fuel Level Sensor 1 High
P0477 Exhaust Pressure Control Relay Low
P0478 Exhaust Pressure Control Relay High
P0480 Cooling Fan 1 Control Circuit/Open (Low Speed Fan Relay)
P0483 Cooling Fan Speed
P0500 Vehicle Speed Sensor 1 Circuit, or No Vehicle Speed Reference Signal 1
P0514 Battery Temperature Sensor Performance / Rationality
P0516 Battery Temperature Sensor Low
P0517 Battery Temperature Sensor High
P0521 Oil Pressure Sensor Performance / Rationality
P0524 Oil Pressure Too Low
P0532 A/C Pressure Sensor Low
P0533 A/C Pressure Sensor High
P0541 Intake Air Heater Relay 1 Low
P0542 Intake Air Heater Relay 1 High
P0562 Battery Voltage Low
P0563 Battery Voltage High
P0572 Brake Switch 1 Low
P0573 Brake Switch 1 High
P0580 Speed Control Multiplexed Switch 1 Low
P0581 Speed Control Multiplexed Switch 1 High
P0602 Control Module Programming Error/NotProgrammed
P0604 Internal Control Module RAM Integrity Failure
P0606 Internal ECM Processor
P0607 ECU Internal Performance
P0622 Generator Field Control Circuit
P0628 Fuel Pump Relay Circuit Low, or Fuel Lift Pump Control Circuit Low
P0629 Fuel Pump Relay Circuit High, or Fuel Lift Pump Control Circuit High
P0630 VIN Not Programmed in PCM
P0633 SKIM Key Not Programmed in PCM
P0642 Sensor Reference Voltage 1 Circuit Low
P0643 Sensor Reference Voltage 1 Circuit High
P0646 A/C Clutch Relay Circuit Low
P0647 A/C Clutch Relay Circuit High
P0652 Sensor Reference Voltage 2 Circuit Low
P0653 Sensor Reference Voltage 2 Circuit High
P0698 Sensor Reference Voltage 3 Circuit Low
P0699 Sensor Reference Voltage 3 Circuit High
P0700 Transmission Control System (MIL Request)
P0837 Four Wheel Drive (4WD) Switch Performance / Rationality
P0838 Four Wheel Drive (4WD) Switch Circuit Low
P0839 Four Wheel Drive (4WD) Switch Circuit High
P1652 J1850 Communication Bus
P2121 Pedal Position Sensor 1 Performance / Rationality
P2122 Pedal Position Sensor 1 Low
P2123 Pedal Position Sensor 1 High
P2127 Pedal Validation Switch 2 Low
P2128 Pedal Validation Switch 2 High
P2146 Fuel Injector Group 1 Supply Voltage Circuit
P2149 Fuel Injector Group 2 Supply Voltage Circuit
P2266 Water in Fuel Sensor Circuit Low
P2269 Water in Fuel Condition
P2502 Charging System Output Voltage
P2503 Charging System Output Low
P2504 Charging System Output High
P2509 ECM/PCM Power Input Signal Intermittent
P2607 Intake Air Heater Relay 2 Low
P2608 Intake Air Heater Relay 2 High
P2609 Intake Air Heater System Performance
Old Dec 25, 2006 | 11:20 PM
I have the BullyDog TripleDog and outlook on the truck, Friday my friend bought a 06 Ford and we thought we would see what it would do. So I put my truck back to stock and downloaded the tripledog 2.3.3 on the Ford and we rode around for a while. I put his ford back to stock and then attempted to Install it back on mine, everything showed to go ok. The Dodge started and ran for ten seconds then died. I have put it back to stock and still no start, so then I uploaded the 2.3.4 and installed on the truck and will not start. I checked the DTC's and it shows PO336,PO513. Being a holiday weekend nobody is at Bullydog and I need the truck running. Just trying to decide weather or not to just take it to the dealer in the morning or wait and try to get ahold of someone from Bullydog.
Thanks for the Help
Casey T ***
Old Dec 26, 2006 | 12:42 AM
TexasCTD's Avatar
YOU PUT A BULLY DOG TD ON A FORD????????????? AND THEN BACK ON YOURS???????????!!!!!!!!
Are you sure they are interchangeable?? I thought that these programmers are only for a specific make of truck and often not even interchangeable year to year on some.
Old Dec 26, 2006 | 06:57 AM
The program is called Tripledog because it is used on 06 Dodge, 06 Ford,06 Chevy It is printed on the front of the downloader. They claim it is able to go on all three makes.
Old Dec 26, 2006 | 07:13 AM
MikeyB's Avatar
Try disconnecting the batteries for 15 minutes or so to clear the ECM memory.
MikeyB
Old Dec 26, 2006 | 10:15 AM
Well called bullydog when they opened this morning and they walked me through. Had to put in a bunch of numbers and my Vin# \. It started right up.
I Unpluged the battery earlier in the weekend but it did not work. The guy at bullydog said that unpluging it does not help when the program is putting out DTC's
Old Dec 26, 2006 | 12:46 PM
TexasCTD's Avatar
OOHHH, ok. I didn't know that. Thanks for the info.
Glad you got it straightened out with Bully Dog!
MY WORLD
Mar 4, 2013 08:47 PM
BBarnett
Jun 22, 2007 04:20 PM
SwingingCCattle
Dec 26, 2006 10:20 AM
Bradleysram
Feb 5, 2005 05:16 PM
