driveline vibration
Old Jun 10, 2012 | 09:09 AM
cath99's Avatar
driveline vibration
local driveline shop removed large weight off of transfercase end of driveline when replacing ujoint. what was the purpose of this large weight on the yoke assembly
Old Jun 11, 2012 | 05:03 PM
dieselfreak21's Avatar
got to love these shops. Although I have replaced all 3 joints and can't get all the vibration gone. Guess the carrier bearing is next.
Old Jun 12, 2012 | 12:48 AM
junebug95628's Avatar
if I'm not mistaken it acts like a harmonic dampener on the drive line. someone correct me if I'm wrong.
Old Jun 12, 2012 | 06:22 AM
I drove 1.5 hours to a driveline shop that was open when the local one (45 minutes away) was closed for vacation. Paid ~100 for them to balance the shaft, and in the process, they removed that large weight just as you mentioned. Took the shaft home, and the vibration was worse, even though I watched them balance the shaft on their machine.
Took it back out, and went to the local guy. He re-welded a large hunk of metal in the same location, and re-re-balanced it. Perfect since.
So I got the shaft with the first guy, and the second guy balanced it right.
Take it somewhere else, or make them re-check it.
Secondly, there is a service bulletin about the 1st gen driveshafts needing shims under the hanger bearing, which corrects the alignment of the rear two piece shafts in the club cab trucks.
pmtg
Jul 14, 2005 03:42 PM
BigBlackCTD
Jun 20, 2005 11:02 PM
1ST GEN.
May 26, 2005 11:48 PM
vavtx
Feb 13, 2005 04:29 PM
GTurn100
Dec 27, 2004 02:55 AM
