Does coolant need additives?
Old Aug 6, 2008 | 01:20 AM
jtharvey's Avatar
Forgive me if this is a dumb question, but do the Cummins engines need any kind of coolant additives? Coming from a 7.3 Powerstroke, I had to test the coolant with test strips every 6 months or so and replenish the SCA additive as necessary.
The engine currently doesn't have a drop of coolant in it and from what I've read here, the Zerex G-05 is the correct coolant for this engine. I plan on flushing out my radiator and heater core to make sure all of the old coolant is out before I put the engine in the truck and fill it, but wanted to make sure if there's an additive I need that I get it in there too.
Old Aug 6, 2008 | 01:40 AM
Diesel Doc's Avatar
I don't beleive it calls for one in the manual but doing it anyway shouldn't hurt anything I test mine and add treatment if needed.
Old Aug 6, 2008 | 04:57 AM
TexasCTD's Avatar
Zerex G-05 and distilled water (50/50) and you should be good to go.
Old Aug 6, 2008 | 07:02 AM
MikeyB's Avatar
The Cummins 5.9 doesn't need the SCA additive.
MikeyB
Old Aug 6, 2008 | 08:55 AM
Roperteacher's Avatar
None required but I use ROyal Purple's "Purple Ice" and it really works to cool the engine quicker.
Old Aug 6, 2008 | 08:56 AM
1985cucv's Avatar
i ran water wetter really noticed a difference in cooling
Old Aug 6, 2008 | 09:52 AM
jtharvey's Avatar
MikeyB
That's exactly what I was looking for...and hoping to hear. Just one less thing I'm going to have to worry about. Thanks for the replies.
Old Aug 6, 2008 | 10:22 AM
D-Roc's Avatar
If you know the history of the truck and it has had regular coolant changes you would probably be fine to just drain and refill with G-05...no aftermarket additives needed. Not a good idea to mess with the chemistry of your coolant system, you don't want any sludge in there.
Old Aug 6, 2008 | 10:39 AM
jtharvey's Avatar
Well, the history of the truck I got my engine from goes something like this. In early 2004, the truck was totaled for some reason when it was brand new...fell of a transporter or something like that. The truck only had 5 miles on it. In mid 2005, A guy in Iowa bought that engine from a salvage company to do what I'm doing with it -- put it in a Super Duty. However, he never got around to doing anything with it at all so he sold the engine this spring and I bought it.
So, I've got a virgin 2004 engine, with only 5 miles on it, that only had coolant in it for a bit. It's been dry for quite a while. When I flipped the engine over on the stand to change the cam, there was not a drop of coolant that came out. I got nothing to drain and flush except my radiator and heater core.
Old Aug 6, 2008 | 11:18 AM
glocklove's Avatar
I put the Royal Purple in my truck also, however I noticed my temps went up, only like 5*,(190 to 195) it drops the temps but not any faster than with out it. Under stand this, I only have the idiot gauge to go buy, and I have only had the RP in the truck about two weeks.
Old Aug 6, 2008 | 11:32 AM
jtharvey's Avatar
I've got Autometer Gauges, and I'll have a coolant sensor in the head to measure actual temp, so I'll see how it does. The Powerstroke radiator, which I'm reusing for this, is pretty beefy. Never once in 5 years did I come close to overheating. But I don't know how it compares to the Dodge radiators and whether or not the Cummins runs any hotter than my 7.3 did.
Old Aug 6, 2008 | 05:06 PM
D45's Avatar
D45
Coolant Additives are a waste.
As recommended by DEI, I poured in two bottles of DEI's Diesel Radiator Relief. Their product states that a 30 degrees drop in coolant temps are expected.
I did not see even a 1 degree difference.......saved your time and money and just run the recommended coolant.
Old Aug 6, 2008 | 05:13 PM
rip 112's Avatar
I just go to Napa and get a bottle of Napakool, works great and isn't expensive.
Cumminsdieselboy
Oct 31, 2004 09:23 PM
apache
Aug 18, 2003 09:22 AM
srowen
May 21, 2003 06:25 PM
