Does anybody know where the list of codes are?
I have 2003 Dodge. Truck attempts to start and then dies original lift pump is working but just bought the Raptor 100 from Lary going to put it on shortly.
Did the Code thing with the key. Code P2509 Pops up anybody know whats going on with this? |
I know the Haynes manual, which can be found at any parts store, has a list of codes in it. Somewhere on this forum you can find what all the codes mean, I'm just not sure where they are located. Give me a minute and I'll try and find it for ya.
Thanks finally found them. Madhat had posted them for somebody else
Thanks Madhat. |
Did some quick searching and found that others have had this code because of one of the two batts being low and giving a drop in voltage, causing this code to be set. Some noted that there was a loose wire at the intake grid heater, but some noted that loads of other stuff had to be replaced, under warranty of course, to solve the same problem you seem to have. Keep us posted on what you find.
I would definitely check your batteries if they are weak. Granted, my factory batteries lasted 8 yrs but I knew something was wrong when everytime I would start the truck and the clock would reset and the cd player would automatically lose track of the last song before shutdown and start all over at the beginning again. Replaced both batteries and everything has worked fine since then. Just an easy place to start. |
Dang, even when Madhat's not here he's solving other folks problems [laugh]!!! Guess that why he's a DTR Admin. Hopefully he helped you fix your problem! Again, keep us all posted on what you find.
Originally Posted by Sittingbull2
(Post 2973126)
Thanks Madhat. EDIT: Think I found some of them. https://www.dieseltruckresource.com/...ghlight=Raptor https://www.dieseltruckresource.com/...ghlight=Raptor |
[laugh] Glad I could help!
Let me know what you need... http://www.dodge-diesel.org/cofaco.html I can usually provide further troubleshooting if necessary. Also, go to the search, then advanced search, there is a google tool bar, plug your code into there, and it'll bring it up just on the forum. |
| All times are GMT -5. The time now is 07:24 AM. |
