Differential fluid change
I'm getting ready to change my differential lube. I know i can re-use the gaskets. My question is, do I need to put the Mopar silicon or permatex grey or whatever on the gaskets?
Thanks L. D. Bryant |
NO.....
nope
I took the covers completely off to inspect the gears/bearings and wipe off all of the sludge that was on the covers. Did this at 15,000 miles and added Amsoil gear lube. Took 4 quarts rear and 3 front. That will put the fluid just under the hole. I took another members advice and torqued all of the bolts to 30 ft. lbs. |
Originally posted by Goldenbear nope I took the covers completely off to inspect the gears/bearings and wipe off all of the sludge that was on the covers. Did this at 15,000 miles and added Amsoil gear lube. Took 4 quarts rear and 3 front. That will put the fluid just under the hole. I took another members advice and torqued all of the bolts to 30 ft. lbs. |
| All times are GMT -5. The time now is 02:35 AM. |
