Coolant leak - please help diagnose
I recently noticed a small puddle forming under my truck. The puddle is directly under the AC compressor / the front passenger-side corner of the engine block.
I got under the truck and snapped a couple pictures looking strait up. The pictures show where the drip is coming from - off of the mounting bracket for the AC compressor. Based on the color (reddish/orange) and smell, I am pretty certain that is is coolant. However, I cannot find the source of the leak. I've checked the main coolant hoses to & from the radiator, and there doesn't seem to be a leak at those locations.
If anyone has dealt with a similar leak, please let me know what your experience was - where the leak was coming from, and how it was fixed.
I think there might be a coolant hose that's located under the alternator - but above the AC compressor. So it's a really tight space, and I can't really see it well or reach it. I'd probably have to remove the alternator. I'll do that if necessary, but wanted to check in here first.
Thanks for any input!
I chose to flush/change while replacing wterpump. Was a little earlier than schedule but was easy enough to do while replacing waterpump. Time to check your belt also as you will need to at least remove this from the tensioner and pump. No need to replace but a good time to take a look at it.
Anybody else have the foil wrapped hose with the hose clamps leak intermittantly? I retorque every year but it still leaks this time of year as it gets colder. Today was the worst ever, after having block heater plugged in last night, there was a 12" diameter puddle when i came out this morning. Any help for a permanent fix?
What hose? Is it one of the ones that goes to the heater core?
My 1st thought is to change the hose. Is it dried up and cracking? Maybe something is just wrong with that piece of hose.
I have never had my truck leak like that.. Had a leak after I modified one of the coolant pipes to put my Compounds on but that was my fault..
Just found the answer on another thread- there's an upgraded hose and spring hoseclamps that will fix.
Thanks JP-4.5
https://www.dieseltruckresource.com/...t=coolant+leak
Thanks JP-4.5
