Confused
Old 08-19-2018, 09:24 PM
Mopar6898's Avatar
Confused
Truck showed P2149 code a few days ago, began rough idle & aquired shimmy coming from rear end but, didn't lose any power or fuel mileage on highway.
Checked all injectors & zeroed out.
Cleared codes, hit highway for 70 miles & no codes.
However, still have shimmy from rear end.
Tires were rotated & balanced before any problems have occurred, so didn't figure that is the vibration problem...
Any suggestions???
Thanks, in advance....
In case it doesn't show:
2006 Dodge Ram
Big Horn Edition
5.9
Old 08-20-2018, 01:12 PM
gcssr's Avatar
Jack the rear end up, set it on good jack stands, block front wheels good. Crank it up put in gear slowly speed the engine up, notice which wheel is bouncing, be cautious, if vibration is severe. apply brake, now you know where vibration is coming from.
Old 08-20-2018, 04:29 PM
Mexstan's Avatar
Possibly a bad U joint?
For wheel balance try Centramatics. Never had my truck run smoother since I installed them.
James2
08-01-2003 09:05 AM
wheels
06-07-2003 07:52 AM
w4xtc
04-30-2003 01:03 PM
Rigg4x4
04-10-2003 07:17 PM
The Boss Hog
12-20-2002 05:03 PM
Quick Reply: Confused
