-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   Codes codes and more codes Help!!! (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/codes-codes-more-codes-help-263313/)
exwrestler Feb 4, 2010 06:44 PM
The following codes keep coming up in my truck.
P0581
P0514
C1008
C2206
U0141
U0184
U0100
U0121
What is causing this and how do I fix it. I have had a mechanic clear these numerous times with no avail? please help
exwrestler Feb 4, 2010 06:46 PM
Would the Banks Ram Air or clockspring cause these? Stuck relays/ Im lost!
OCMerrill Feb 4, 2010 07:05 PM
P0581 Low Voltage Detected At The Speed Control Switch
P0514 BAT Temperature Sensor Rationality
U0141 Lost Communication With Fcm (tipm)
U0121 Lost Communication With Anti-lock Brake Module
All I can find.
How are your batteries? I know the Can-Bus trucks are real sensitive to battery voltage. condition, and corrosion.
exwrestler Feb 4, 2010 07:10 PM
They were tested and cleaned also the alternator was also tested and good.
tesla440 Feb 5, 2010 08:44 AM
it could be a power issue. Have the batteries been load tested. Bad batteries will cause codes to be thrown.
nascar-co Feb 5, 2010 09:34 AM
I am no expert but that looks like it could be a bad ground. The codes point to a power issue but if the batteries are good and the alternator was tested a bad ground would be what I would look for.
