Clutch issues
Old Apr 8, 2013 | 01:55 PM
PSU927's Avatar
Clutch issues
About 3 months ago my wife backed out of the driveway and when to pull away and she told me she couldn't get the truck in gear. So she didnt think to shut it off and try so she let it set. I cam later and started it and it went right in gear no problems since. I thought she was nuts to be honest. Well today I pulled in my driveway and then went to put it in first to park it which I always do while it's running (just my habit) and it won't go in gear. Unless the truck is shut off. When I push the shifter hard the truck starts to move so for some reason the clutch is not fully engaging. Ideas? Seemed to only do it when warm but the other day it did it right away in the morning. Shut the truck off for 10 minutes, went back out and it drove fine. This one has me perplexed to say the least.
Old Apr 8, 2013 | 02:01 PM
rockcrawler304's Avatar
Is it only when going into 1st?
How does it shift otherwise?
Old Apr 8, 2013 | 02:08 PM
PSU927's Avatar
No, any gear. (reverse, etc...) if I shut the truck off and start it in gear, I get get going and shift on the fly but when I stop I can feel the clutch "grabbing". Soon as I let it out, I cant get it back in any gear.
Shut it off for 10 minutes or so, and she will work fine.
Old Apr 9, 2013 | 12:29 PM
dirty pete's Avatar
Just a shot in the dark, did you check the clutch slave cylinder to be sure it is full of fluid?
I had almost the same problems and I had to replace the slave cylinder assembly. Good Luck.
Old Apr 9, 2013 | 12:41 PM
It also sounds like a slave cylinder to me.
Old Apr 9, 2013 | 03:27 PM
PSU927's Avatar
Plenty of fluid. The master and slave assembly comes as one, pre-bled part correct?
Old Apr 9, 2013 | 05:27 PM
dirty pete's Avatar
Mine did for my 03. Well so much for the obvious.
matthopp
27
Apr 20, 2017 08:21 AM
Hammer
Aug 1, 2007 11:33 PM
corndog
Nov 30, 2006 05:19 PM
apache
Sep 30, 2006 12:51 AM
getblown5.9
Aug 23, 2005 09:08 PM
