-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   CLUNK when turning? (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/clunk-when-turning-310212/)
WEATHERBY460 Feb 16, 2013 12:58 PM
CLUNK when turning?
I am getting a clunking sound from underneath the truck when I am turning. The u joints look good, except I do have a little/slight wobble in the joint that is coming off of the transmission underneath the rubber boot that attaches to the drive shaft...could that be the issue? Thanks
ajpulley Feb 17, 2013 05:12 AM
I had an occasional clunk when turning, or backing up and stopping. It wasn't repetitive with tire or engine RPM. It would happen going slow (or I could hear it going slow), but not every time when turning. Sometimes, I would backup, stop and clunk. Then go forward, stop and clunk. Shocks needed to be replaced anyway, so did that. Checked control arms, ball joints, drag link, etc. and couldn't find it. A year later, I found it... a sway bar link. Replaced both and knock was gone.
mwheaty Feb 17, 2013 09:07 PM
i also had a clunking when turning but it was the u joint on the passenger side, one of the collars had cracked, didn't actually find it until the crack became a failure and the whole leg of the u joint gave out and all the needle bearings fell outta it.
railroaderone Feb 18, 2013 10:48 AM
May also want to check the track bar bushings. Thats the cause of the cluck that i had
