Checking for Trouble Codes?
Old Jan 12, 2012 | 03:59 PM
fatpete's Avatar
I need to check for any stored codes (trans probs, etc). I have no check engine lights. Is this something that can be done with any OBDII code reader or do I need to have the dealer use the special Dodge one? Thanks for any help.
Fatpete
Old Jan 13, 2012 | 07:04 AM
Hintonc393's Avatar
Most scanners can do that, the historic codes will show up as inactive. Most of the cheep scanners will not do trans codes though. You can do a search for the method to pull the codes out of the odometer, I think that should give you all codes stored in the ECM.
Old Jan 13, 2012 | 07:12 AM
madhat's Avatar
Administrator/Jarhead
This will give you basic stuff, if you want the real data you need to get it scanned by a dealer or someone with a real scanner...
https://www.dieseltruckresource.com/...s-t224833.html
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
tacohat
Jul 17, 2006 02:27 PM
DarrellB
Sep 6, 2003 04:49 PM
