-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   Check Guages Light (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/check-guages-light-67147/)
Brian Tiffany Apr 28, 2005 08:49 AM
Check Guages Light
This morning on the way to work my Check Guages light came on for a shot time (2-3 seconds). When I got to work I used the key on/off trick to check codes and there were none. Do you guys have any ideas what is causing this condition?
Jonesey Apr 28, 2005 09:57 AM
This is a problem or should I say a minor annoyance with the early 03s. Mine does it occasionally. There was a TSB but it requires the radio to be unhooked if you have the high-end Infinity system. For this reason I decided to just live with it. It doesn't do it often enough to bother me. It did do it yesterday. That was the first time I have noticed it in months.
MikeyB Apr 28, 2005 11:00 AM
Same here. I just ignore it.
MikeyB
redneck1 Apr 28, 2005 12:19 PM
Mine does it too. It's just an annoyance that I learned to live with.
miketriton Apr 28, 2005 02:25 PM
Is it associated with a chime? If it is the same as mine, it is a loose connection on one of the tail light bulbs. I tightened up the bulb connectors and it goes away.
Brian Tiffany Apr 28, 2005 03:01 PM
I think that I've found my answer. TSB 08-004-03 is for an Electro Mechanical Instrument Cluster flash. It states that it is a reflash to the MIC software.
I was wondering if this is a reflash of the ECM also. Anyone got any clues?
pcburnout Apr 28, 2005 03:41 PM
I've seen mine do it too and it seems to be a catch of the eye thing cause its just a second. Mine has not done it for a long time though:confused:
