check Engine Light no codes
The little orange motor is lit on my dash...The truck runs fine. I took it to a local parts house and they plugged it in and no codes come up. I have an edge Juice with attitude on it..its an 05 170000 miles. I had it since new. The edge has been on since almost new.
The Edge Juice is an interceptor module, not a programmer, so it won't interfere with the OBDII port.
If your CEL is on, there is DTC's stored but likely you need a more advanced OBDII scan tool to read the codes.
Try the key off/on 3 times procedure to see if the stored DTC's come up on the dash gauge cluster.
If not, it might be easiest to take it to the local Chrysler dealer.
I only put that out there because I had a truck in the shop with some sort of edge product that wouldn't let any scan tool read it, until we went into the edge module and set it stock settings.
I believe that is the turbo waste gate solenoid. Sometimes it's the wires and connector, or the solenoid itself is bad. Should be able to change the solenoid.
Edit------- I dug up this old post for you. Hope it helps.
https://www.dieseltruckresource.com/...html?styleid=1
alltimelow1
04-06-2005 07:28 PM
Jc9995
0
11-29-2004 10:21 AM
Copenhagenjunkie
16
07-25-2003 11:18 PM
