check engine light
my 06 2500 6 sp. popped up a check engine light. only has 1300 mi. and is all stock. has anyone else's light came on and what did you find out. I do have an appt. with my dealer on 4-3-06. thanks in advance.
Have you tried the key switch code check yet, on-off-on-off-on(leave in on position) the codes should pop up in the odometer spot. Get the codes and we can help you further.
thanks, the code is p0111. is there an easy way to reset the. the codes if/when i can resolve the problem?
P0111 Intake Air / Charge Temperature Sensor Performance / Rationality
thanks df5152, sorry about the slow reaponse.
