Carrier Bearing Again...How too???
Old Feb 25, 2007 | 11:28 PM
Tiara3100's Avatar
Seems every winter I get that "Howl" under my truck when its cold from the carrier bearing. And every year it gets replaced under warranty. Well, it's back again and I would like to fix it for good this time. Two questions:
1. Whats involved in changing this bearing?
2. What's the best way to stop the "Howl" from comming back?
Thanks....
Old Feb 27, 2007 | 11:03 AM
Robert373's Avatar
Mine has a howl also. Does yours just do it for a second or two, and then go away? Seems to do this howl only when accelerating/deaccelerating.
My truck has done this since new (but worse when its cold), and the carrier bearing (actually the entire drive shaft) was been replaced and it still does it.
Just wondering if its worth the bother to take it to the dealer or is it another chronic problem that never goes away, and the dealer tells you (essentially) its "supposed to do that."
Also just for your info, I found a driveline company that sells a carrier bearing that has a urethane support instead of rubber, may be an option. I will have to dig around for the website.
Old Feb 27, 2007 | 08:18 PM
Tiara3100's Avatar
I usually get the howl around 25-35mph when it's below 30 degrees. I get it both accelerating and decelerating. I have had the dealer replace it three times. It goes away for a while but always seems to come back in the following winter. Let me know about that urethane support.
Old Feb 28, 2007 | 09:38 AM
Robert373's Avatar
PM has been sent.
Old Mar 1, 2007 | 09:51 AM
ednerin's Avatar
Could you please post the website for the urathane carrier bearing support? Thanks
Old Mar 1, 2007 | 07:06 PM
Dynocon's Avatar
Mine does the same thing. 20-25 MPH, 20-30 deg F. Let me know what you find out.
Old Mar 1, 2007 | 07:10 PM
belgianmagic's Avatar
Make A Spacer To Put Between The Carrier And The Bracket...to Drop The Bearing Down Closer To The Ground...1/4 -1/2 Inch
Old Mar 1, 2007 | 07:11 PM
You Will Need To Make It Out Of Flat Stock Steel Or Something Like That
Old Mar 1, 2007 | 07:29 PM
Bad Ramer Jamer's Avatar
So how about a link for that bearing.
Old Mar 1, 2007 | 08:24 PM
Tiara3100's Avatar
http://www.iedls.com/bearings.html
ajb1974
Mar 18, 2015 05:49 PM
jmlcolorado
Nov 29, 2009 01:32 PM
bishgeo
Oct 28, 2008 08:45 AM
Joseph H. Smith
16
Jan 6, 2007 08:13 PM
rich
0
Oct 4, 2002 06:18 PM
