Can't get the torq screws out of the FCA
Old Oct 10, 2013 | 08:11 PM
Hi Pockets's Avatar
So I get the diagnosis. FCA is bad. I pick up the new one at Max Torq Diesel in Golden Co. Get it home, grab my T25 torq bit and proceed to rupture the blood vessels in my right eye while trying to get the first one out.
Are they supposed to be that **** tight? I'm afraid of stripping the head out if I put a ratchet on it.
If you have any ideas or have run into this issue, please let me know how you felt with it.
Thanks for the look and help
Old Oct 10, 2013 | 09:48 PM
Spooler's Avatar
Try tapping on the torx bit to break the Loctite loose.
Old Oct 10, 2013 | 10:15 PM
VaultRam's Avatar
I sprayed a little PB Blaster on the bolt heads the night before. I actually only got to the top and side bolt and not the bottom bolt with the PB Blaster...I could tell a huge difference by the ones sprayed. Also, try what spooler said!
Old Oct 10, 2013 | 10:18 PM
torquefan's Avatar
A tiny bit of heat applied to a bolt makes a huge difference in softening up the locktite. Just not sure on the FCA how safe it is to apply heat to that area, with the risk of damaging seals etc.
Old Oct 10, 2013 | 10:28 PM
Hi Pockets's Avatar
Thanks guys
I just sprayed some of the new, WD40 product on it. I will let it sit over night and give it another shot in daylight. I'll give them a good tap too
Thanks!
Old Oct 10, 2013 | 10:29 PM
DragonSlayer's Avatar
Put a ratchet on them screws after the above posts.....worked on mine.
Old Oct 10, 2013 | 10:39 PM
Hi Pockets's Avatar
I was actually thinking about hitting it with an impact.
Old Oct 10, 2013 | 11:24 PM
Spooler's Avatar
If you can get to it, that is the best way. Use a 1/4in impact if you have it.
Old Oct 11, 2013 | 08:03 AM
MikeyB's Avatar
Mine came out pretty easily after tapping the screw heads with a hammer and a brass drift.
Old Oct 11, 2013 | 10:32 AM
.boB's Avatar
Not sure about the new penetrant from WD-40. But I'v been using BP blaster for years with pretty good results.
The best rust buster is a 50:50 mixture of auto trans fluid and acetone.
Get a hand impact tool. For screws it works a lot better than any other type of impact wrench. You risk of rounding out the screw head is almost zero.
Old Oct 11, 2013 | 02:23 PM
Hi Pockets's Avatar
Well I did it. Two out of three came out this morning. Not bad. Except the first one stripped. I've tried vice grips as a last resort and still no luck. ID like to meet the gorilla that put these on.
Anybody dealt with this one yet? Or am I just special?
Thanks again for all the suggestions
Old Oct 13, 2013 | 08:36 PM
Hi Pockets's Avatar
Grabit
Has anyone had any experience with the Grabit extractor. I'm thinking about trying one on the stripped torx head.
Old Oct 13, 2013 | 09:47 PM
EDR's Avatar
EDR
I have a set from Sears and they have always worked fine for me.
06RAM2500
22
Mar 10, 2012 07:25 PM
madhat
39
Nov 20, 2010 08:22 PM
madhat
Sep 9, 2008 07:03 PM
draskobnsf
17
May 29, 2007 08:29 PM
