building tranny VS buying new one???
Old Apr 2, 2007 | 04:44 PM
CTDowerTN's Avatar
i've just been thinking, and noticing, when i see people saying there trannys shot, and just buy say a whole new HTS or Goerend tranny... why would u say some build the stock tranny, VS buying a whole new one?? seeing i just put in a HTS TC,VB, & input shaft.. iam just wondering if there is any benefit difference in building a stock 48re vs. buying a while new one..???
Old Apr 2, 2007 | 05:01 PM
cameroneod's Avatar
From Goerend Bros
A Goerend complete transmission comes with the following upgrades:
* New triple-disc torque converter
* Upgraded valve body.
* 4140 steel 1-2 lever.
* New Dodge input shaft and hub (non-billet).
* All bearings are replaced with new Torrington bearings, including the output shaft roller bearing.
* New overdrive sun gear is installed with the late style bushings (this will force lube oil out to the gear teeth).
* New snap rings are installed in the front & overdrive clutch.
* New seals & gaskets are installed using the updated versions.
* New release spring in the rear clutch.
* We install a steel front planet gear in all Diesel and V-10 transmissions. Early models (1995 and earlier) may have come with an aluminum front planet.
For 48RE transmissions:
* The front planet is a 6 pinion steel planet and the rear planet is also a 6 pinion steel planet.
* The intermediate shaft is the dual lube hold design shaft.
* The overdrive planet gear is the late design 15* angle with the large lube slots cut into the carrier frame to allow more lube oil to get to the planet pins.
Also, on 48RE transmissions:
* The overdrive planet is a 6 pinion. The overdrive direct clutch is the 10 plate design, including the larger apply spring.
* The overdrive direct clutch has 23 single sided plates.
* The overdrive clutch is the 5 plate design.
* The Trans case is drilled for extra lube to the rear one way roller clutch.
Sounds good to me.
dodgemaniac
Competition / Pulls / OffRoad
Jul 22, 2009 07:01 PM
JKM
May 20, 2008 07:59 AM
hmknight
Feb 25, 2007 11:02 PM
heavyboostin
Jan 29, 2005 02:19 PM
Shovelhead
Sep 2, 2003 10:37 AM
