brrrr, cold start this AM, revving @ 1KRPM ?
Old Nov 19, 2008 | 09:36 AM
buggz's Avatar
Hello,
It was cold in metro ATL this AM, 27degF.
Don't laugh, that's cold for here.
Anywho, I went to start my truck to heat it while I finish preparing for yet another work day, start up went okay, turn key to ON, wait for the air/fuel hearter symbol to disappear, then started right up as normal, no smoke, no problems.
Anywho, after I finished brushing teeth, etc, opened my house door, gee, that sounds loud.
Opened the truck door, and the tach was showing 1KRPM.
Hmm, that's never happened before, even on other cold days, though, not as cold as today.
Anywho, I took it out of park, and the RPMs immediately went to normal idle, 750RPMS.
So, I'm guessing this is normal ?
Shrug, it drove normally.
Old Nov 19, 2008 | 09:40 AM
cheadlesram2500's Avatar
It was a cold start in hilton head island also. my truck seemed ok. but it did run a little high rpm's. so it just may b normal. my brother said his Bmw m3 did the same thing that my truck did. so it could be a little warm up stage
Old Nov 19, 2008 | 09:58 AM
cowbizzoy's Avatar
sweeet sweeet high idle.....it'd neeeeever warm up if it didn't do that.
Old Nov 19, 2008 | 10:24 AM
tmills's Avatar
I'm not sure what year truck you have, but the 06 and 07 have the high idle when it is really cold outside.
Old Nov 19, 2008 | 10:29 AM
ronc's Avatar
When the ambient temp is 32 deg F. your truck will idle up to 1000 rpm, perfectly normal. For some reason my truck did not idle up this morning and it was 25 degrees.
Old Nov 19, 2008 | 10:31 AM
05HDRAM's Avatar
If it's cold enough, the truck will automatically kick the rpms up to 1K. It will drop back down as soon as you step on the brake. I bought my truck new, and I still have not figured out what triggers the rpm kickup when temps seem the same. One day it does it, next it doesn't.
I usually kick mine up manually, so I don't see it very much anyway.
Old Nov 19, 2008 | 11:44 AM
rip 112's Avatar
My truck it will kick in below 40* It is normal.
Old Nov 19, 2008 | 11:59 AM
bhaner's Avatar
Wait untill it starts and goes right to 1000 rpm.
I think it has to be below 20° to do it.
Sounds very crunchy.
Wish it would wait for oil pressure...
My 07 has not done it yet, but my 03 did a few times.
Old Nov 19, 2008 | 02:41 PM
ronc's Avatar
I was told by Cummins on the phone, the high idle will kick in when the ambient temp is below 32 degrees F.
Old Nov 19, 2008 | 03:34 PM
0524VHO's Avatar
Is there supposed to be a high idle for 05. I dont think my truck does? just wonderin
Old Nov 19, 2008 | 03:38 PM
Raspy's Avatar
My '04 had to have it enabled. Maybe yours does too. I like it.
Old Nov 19, 2008 | 03:54 PM
fredbert's Avatar
My '05 just did it for the first time this season! Overhead said 30*F.
Old Nov 19, 2008 | 06:01 PM
nelrod's Avatar
My 06 did it today after a couple of minutes, nice. I need to get the part an plug in ECM so I can Idle it up with the cruise control.
Old Nov 19, 2008 | 06:05 PM
rjm022's Avatar
04.5 truck has the automatic high idle when temps are 32 or lower. the manual high idle had to be enabled at the dealer.
