Which Brand of U Joint
I'm in the process of gearing up for Ball Joint replacment and thought that since the front end is coming apart that I should probably replace those axle U Joints while I'm at it. So far I've purchased the XRF upper and lower ball joints which everyone seems to recommend. Is there any recommendations on U joints? The only ones I'm seeing are the Spicers and Stock ones..... Also, is there anything else I should replace in addition to these items? All the Tie Rod ends have recently been replaced with NAPA stock.
Thanks for any replies |
I've always had great luck with Spicer products.
Every u-joint that's gone out on my truck has been replaced with greasable Precision u-joints from NAPA and have been flawless since installation. I'm sure there are better/more expensive joints out there but these have done well for me. Sorry I don't have P/N's but they can pull them up for you.
precision not precise!
I have had excellent luck with the greasable Brute Force U-Joint From NEAPCO
The only one I will use is the non-greasable Spicer Life u-joint. They are sealed from moisture intrusion far better than any greasable joint, and they were the OEM u-joint on Dodge trucks until they switched to the horrible AAM joints in 2003. My 96 still has factory Spicers in its driveshafts after 14 years, as do most of the 2nd gen trucks I know of.
Some guys will also remove their wheel-speed sensor from their front hub/bearing and pump some bearing grease in there while it's apart. I don't have any personal experience with that, so I'll let you be the judge on whether it will improve longevity or not.
I am in need of front u-joints too.. Spicer has always been good to me.
Originally Posted by 1slo_MM
(Post 2703601)
Originally Posted by torquefan
(Post 2702535)
Originally Posted by scottsjeeprolet
(Post 2703932)
That won't do any good as the Unit bearing bearings are sealed grease for life bearings. They are not serviceable.
The bearings them selves are sealed. That's why they are called grease for life. The grease you put in the ABS hole isn't going to get into the bearings. But if it makes you feel better go ahead and do it.
Originally Posted by 1985cucv
(Post 2702426)
I just replaced my ujoints with the precision 330A. I got about 120k out of the last precisions so I guess that I an't complain about that.
Jim |
