Boost leaks
Old Oct 31, 2014 | 06:18 PM
CRToney's Avatar
Boost leaks
I had my '03 only develop 26 psi of max boost. It usually will do 35+. I took a spray bottle with soapy water with the truck idling and sprayed all my places for a possible leak. I had bubbles at my intake horn to grid heater. The bolts were just a tiny bit loose. I resealed it with a new gasket. Hopefully I'm back in business.
Sent from my iPhone using Tapatalk
Old Nov 3, 2014 | 05:46 PM
CRToney's Avatar
I'm not back in business. Still only 26 psi. Why else could I be lacking power? Last fall I had 50 hp injectors installed. I run my smarty Jr. on tow 85 pod. The waste gate is non functional. The actuator rod doesn't move so it shouldn't be opening. I'll do some more checking with soapy water. My egt is low as it is not getting air thus no fuel.
abchoppers
Jan 26, 2011 05:38 AM
CTD2001
13
Sep 6, 2005 05:11 AM
thumbs
Jul 20, 2004 10:49 AM
Crimedog
May 25, 2004 09:18 AM
thumbs
Oct 22, 2003 01:02 AM
