best air filter
Old Jan 17, 2010 | 12:26 PM
gregn's Avatar
best air filter
What is the best air filter for my 2006 Dodge Cummins? Thanks.
Old Jan 17, 2010 | 01:16 PM
Pull Ya's Avatar
Suprisingly the stock filter is one of the best you can buy. If you really feel the need to change then try a PSM system. Cheap, effective and it works well. If you don't have 500+hp you really don't see much gain from an aftermarket system. Those high dollar systems are nice to talk about, you get a decal for your truck and you probably just wasted about $400-$500 you could have used on something else. IMO.
Jay
Old Jan 17, 2010 | 01:23 PM
annabelle's Avatar
Jay
X2.....mod your box and go with a stock filter.
Old Jan 17, 2010 | 01:41 PM
Fiftygrit's Avatar
I did the mod on my air box, worked fine, in the last 2 weeks I put on a S&B cold air intake, you get a little more whistle but I also got maybe 1/2 to 1 more miles per gallon on the intersatate, time will tell with this, only 2 tanks thru it so far. good luck
Old Jan 17, 2010 | 02:53 PM
6 Shaker's Avatar
X3.......on modding stock air box and going with the PSM mod. None of the aftermarket filters come close to matching the filtering efficiency of the factory/Fleetgaurd filters. And this setup is good up to around 500 rwhp and based on your signature you're nowhere near that.
Old Jan 17, 2010 | 04:55 PM
hector's Avatar
I just bought the new oem dodge filter here http://cgi.ebay.com/ebaymotors/03-04...Q5fAccessories
less than local dealer
Old Jan 17, 2010 | 08:16 PM
beewize's Avatar
What is the psm intake system exactly. never mind i found it thats cool, ha.
Old Jan 18, 2010 | 08:26 AM
72dart's Avatar
I had a thread, a while back, on the new taller filter for the factory airbox. I bought some and love them. I never see smoke after I punch-it, and I noticed my milage went up .5-.7 MPG. They cost about $26.00 a piece.
Old Jan 18, 2010 | 10:00 AM
AlCorr's Avatar
Is that $26 ea at the dealer?
Old Jan 18, 2010 | 03:38 PM
DBLR's Avatar
Fleetguard air filters at Genos are only $14.95 its the same as the Mopar air filter but they cost $26.95. They also have the one bigger air filter for the 6.7 at $29.95.
Old Jan 18, 2010 | 07:06 PM
CRToney's Avatar
I run a Pro Guard 7. It doesn't get sucked in if it gets wet. I don't like the oil but turbos don't like paper.
Old Jan 18, 2010 | 08:10 PM
Danderson's Avatar
I called Genos about getting the new 5.9 deeper filter. They were unaware of it's existence. Hopefully,with enough interest they can offer some at a good price.
Old Jan 19, 2010 | 07:19 AM
dott's Avatar
Nice find. I gotta have it.
Old Jan 19, 2010 | 07:29 AM
AH64ID's Avatar
I have been running the Amsoil, with good UOA results. It traps a TON of dust, it does require cleaning often, but I guess that means its working.
I hope amsoil makes a new deper one.
Old Jan 19, 2010 | 08:21 AM
Poke In Da Eye's Avatar
Does Amsoil make a dry filter or are all of theirs dry??
