Backspacing
I found some wheels that I like and they are 4.7" (4 11/16") BS. I think this w/ 35x12.50x17 will rub the rear of the fender. Anyone running similar backspacing and having success w/ it?
http://cgi.ebay.com/ebaymotors/ws/eB...AQ:MOTORS:1123 |
I think you're right...they're going to rub pretty badly.
Why is it that every wheel I like doesn't have the dimensions I need?! [laugh]
Here's a handy way of getting an idea on different wheel and tire combos.
http://www.1000rims.com/rt_specs.jsp For the left one, put in stock specs... I think 17 x 8 wheel with +42 mm offset, and 265/75 tire. On the right hand side, enter in info on the wheel/tire combo you're wanting to run. At the bottom, it tells you exaclty how much the new combo with stick out, and offers suggestions. --Eric |
The specs say 17x8 with +25mm offset, which means those will work great.
Where did you see the specs?! I couldn't find anything (could be due to my lack of PC skills).
You'll need at least 5.5" of backspacing and a positive offset. Mine is positive 14mm offset and 5 5/8" backspacing--- no rubbing with a level kit.:cool:
| All times are GMT -5. The time now is 10:12 AM. |
