| Kwkrnu |
Nov 24, 2025 09:32 AM |
Auto Trans Issue
I just completed some repairs to my 2006 3500 Dodge diesel. It has 200k miles on it. The tranny was rebuilt by a local shop about 5 years ago by the last owner at around 35k miles ago. He had the billet converter installed as well as adding extra coolers. I used the truck to pick a car I bought in Houston, TX last November. We made the trip with no issues, and I have been driving it nearly every day since. In late August I parked the truck to do some work on it and then got sent out of state on a project. I worked on the truck on the weekends when I was home and finished it up yesterday. The work I did was replace the AC compressor and dryer and flush system, replace w/p, t-stat, idler, tensioner, belt, and fan clutch (with Ford viscous) and both batteries. That's enough history so here is the issue. I started it up yesterday for the first time. When I put the trans in drive it goes to second gear. I can manually shift it to first to get it into low and when I start off and put it back in drive it will only upshift to second. I have no 3rd or 4th gear. The oil is clean and is not burnt. Like a said when I parked it, it worked great. Any thoughts would be appreciated. Thank you!
