Which Amsoil Motor Oil?
Old Apr 6, 2008 | 09:33 AM
  #31
AH64ID's Avatar
Originally Posted by rjm022
5,000 miles for the oil filter and 20,000 miles for the bypass filter- even though amsoil says 25,0000 miles
Actually the bypass is good for 60K, or 2 full flow changes...
Thats a ton of money in oil filters....
Old Apr 6, 2008 | 10:29 AM
  #32
John Faughn's Avatar
Use oil analysis to know when to change oil , it is the only way to KNOW when the oil needs changing , any millage is just picking numbers out of thin air .
The idea here is to get the best lube for the longest at the cheapest price .
Its like buying part to see what is wrong with your truck , thats a fools game , testing is the only way to know .
Some will get high metal in there 1 report [ many think this is old metals flushing out ] , then after the 2nd analysis [ do a analysis at maybe 10,000 then 5,000 ] it should be stabilized and then maybe every 10-20 thousand , this is just to get the concept across , the idea being is that there is at lot of trucks out there , set up all sorts of ways , everyone is not going to get the same results .
And do not forget to check TBN - the 1st part of the analysis is to see whats in the oil , the TBN is to see if the oil is still good .
There are a lot of reports of over a million miles on syn oil & changing filters .
Old Apr 7, 2008 | 11:30 AM
  #33
DBLR's Avatar
Originally Posted by ah64id
So why get the stratapore which is a 25 micron filter when for a few bucks more you can get a 15 micron filter that lasts longer? Especially if your already running amsoil....
Before I buy Amsoil filters I want to get rid of the Fleetguard filters I have on hand.
Plumb Wild
Mar 23, 2010 08:26 PM
Spooler
28
Dec 26, 2009 10:16 AM
czkid
Oct 18, 2007 07:38 PM
Kodiakcb
30
Apr 9, 2007 11:14 PM
Jmac
Nov 14, 2004 05:09 PM
