aftermarket lift pump
Old Oct 18, 2006 | 07:33 PM
brickenbone's Avatar
How hard are the after market fuel pumps to install?
Old Oct 18, 2006 | 08:52 PM
jaredb900rr's Avatar
Here's the Glacier Kit, and the directions on the install can be found here.
I will be doing the install tomorrow evening, I'll let you know how it goes!
Jared
Old Oct 18, 2006 | 08:56 PM
DmaxEter's Avatar
Not hard at all. Well worth the couple of hours to install one.
Old Oct 18, 2006 | 09:00 PM
crobtex's Avatar
I have the FASS HPFP and it was a piece of cake to install. Check it out here .
Old Oct 18, 2006 | 09:17 PM
SupaDupa's Avatar
My GDP Walbro kit wasn't hard to install at all. It's just a PITA working in some of those tight areas!!!
Old Oct 19, 2006 | 08:27 AM
Peterbilt's Avatar
For the 04s with pump on filter, does the Glacier come with a plate to mount on the filter like the FASS kit has?
Pete
Old Oct 19, 2006 | 08:42 AM
nfsommer's Avatar
what happens if you put an extreme hp FASS on your truck when you only have like 375 rwhp?
Old Oct 19, 2006 | 10:06 AM
redstreak's Avatar
You'll have some really good FP.
Old Oct 19, 2006 | 11:24 AM
MikeyB's Avatar
Pete
Yes.
MikeyB
Old Oct 19, 2006 | 03:14 PM
rodaniel's Avatar
jaredb900rr,
How do you like the MBRP muffler (MK96116?) and CAT "delete" pipe combination? Is it a lot louder than stock cat/muffler - at idle? -at highway speed? -at WOT?
I'm looking into the same setup, but haven't heard one yet.
Old Oct 19, 2006 | 03:25 PM
Sailpipes's Avatar
The install for the GDP fuel pump kit wasn't too bad. It's super quiet also. The kit comes with a fitting to attach to the back of the filter canister where the stock lift pump was.
The 2 micron filter with the big line kit is also a pretty easy install. I like the thought of having better filtration.
Old Oct 21, 2006 | 12:05 AM
five20too's Avatar
Will the Walbro or FASS install void any or all of the factory warranty?
Txwelder
Nov 26, 2025 01:53 AM
schu777
Sep 10, 2009 08:50 AM
Bigsmoke3500
16
Jan 1, 2008 09:32 PM
Txwelder
May 19, 2005 06:10 PM
Stamey
Dec 31, 2002 02:20 PM
