-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   AC Pressure Switch Question (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/ac-pressure-switch-question-281684/)
raiderred77077 Dec 5, 2010 10:35 PM
I posted this in the performance forum by accident and wanted to re post in the correct place. Sorry about that.
I have a 2007 Dodge 2500 w/ the 5.9L that is having AC issues. Yesterday the everything worked fine and today nothing. I turn it on and the clutch on the compressor is not engaging. I checked for leaks, and the system has 100 lbs on the high and low side w/ the compressor off obviously.
I checked the voltages on the terminal that plugs into the pressure switch and I am showing 5 volts when I have the AC button engaged and off. From reading an old post Madhat it looked like the pressure switch does operate b/t .451 to 4.519 volts. Here is the a partial quote from his post:
For the air conditioning system to operate,
an A/C pressure transducer voltage reading between
0.451 and 4.519 volts is required. Voltages outside
this range indicate a low or high refrigerant system
pressure condition to the Powertrain Control Module
(PCM) or Engine Control Module (ECM) depending
on engine application. The PCM/ECM is programmed
to respond to a low or high refrigerant system pressure
by suppressing operation of the compressor.
Refer to the A/C Pressure Transducer Voltage chart
for the possible conditions indicated by the transducer
voltage reading.
So how do I find this A?C Pressure Transducer Voltage Chart or a wiring diagram for the HVAC system on this pickup? Thanks for the help folks!
jhenson Dec 5, 2010 11:24 PM
Hmmmm....Madhat any input on this? I'm sure some others might be wondering the same thing. Thank goodness my '03 has had most of the a/c system replaced by yours truly and blowing extremely cold.....oh, wait, this thread was on how to just get the thing work [duhhh].....Madhat...anyone???
