Ac not blowing cold
03 5.9 cummins a/c is blowing hot hooked gauges up and got 40 on low side and 150 on high start the truck turn a/c on clutch engages low side draws down to 0 and high side goes to 300 quick I’m thinking it the office tube but not sure needed help |
Truck on startup without the fan fulling enough air your going to get higher temps on the high side till air cools the condenser. Did you do a compressor replacement, just add 134?
