48RE shifting?
Old Jan 21, 2004 | 10:30 PM
Big Bob's Avatar
48RE shifting?
I now have 3300 mile on the Ghost Rider.
When accelerating WOT though the gears, 1st shifts into 2nd at 3100-3200 RPM, 2nd shifts into 3rd at 3100 to 3200 RPM, (the next shift is where my problem is) 3rd shifts into 4th at 2500 RPM! (no slipage) This is at WOT! If I hold it manually, and manually shift, the transmisson slips between 3rd and 4th.
Is anyone else experiencing this? I went to the dealer today and he said that he has no way to change the shift points on the transmission. Is there a way to change these shift points?
Also while driving normally, it locks up in OD at 50 mph, bringing the rpm down to between 1300 & 1400 RPM. I feel this is much too low. Dealer again said that he has now way to adjust the lockup. Can this be adjusted?
Old Jan 22, 2004 | 09:52 AM
ssteve's Avatar
I like the lockup into overdrive at 50 even though it does seem a little soon. I don't think they can adjust it without taking out the valve body and than the tech would have to know what he's doing.
Steve
Old Jan 22, 2004 | 08:08 PM
RickE's Avatar
The 6spd shifts whenever you want it to.
Old Jan 23, 2004 | 11:56 AM
04RAM2500's Avatar
Thumbs down
I have experienced the same, on my 04. It only has 1000 miles and does the same. I think the truck would feel faster if it would hold 3rd longer.
At WOT the truck is decent but not a racer by no means. I wonder if any power mods will change this. Maybe someone with a box can respond. Does the Edge change anything in the tranny??
Thanks Guys
Old Jan 24, 2004 | 04:48 PM
mymaur's Avatar
Turn off your over drive and you can take it to redline for the last shift. Then push the button and the OD shifts and torque converter locks. I do it all the time when I want to get into traffic.
Old Jan 25, 2004 | 06:17 AM
rjweiss's Avatar
Turning off the OD works well for me too.
Ron W.
Brendan
Oct 17, 2007 11:12 AM
98 Ram 24V
Dec 24, 2005 10:19 AM
bigtobe
Oct 28, 2003 03:19 PM
dansdad
Sep 6, 2003 09:00 PM
courtndd
May 29, 2003 05:07 PM
