48RE question
Old Nov 19, 2009 | 11:36 AM
michiganracer2's Avatar
48RE question
I just purchsaed a 2005 DRW with a 5.9L and 48RE with 66,000 miles.
I have read alot about these trans on here and understand what everyone is talking about with the 2nd and 3rd gear change.
i have put about 3,500 miles on it and the one thing I feel is like a double shift into Hi gear, or 5th gear. When empty its not to bad, when I pull about 12,000# 5er it hits hard but not terrible hard and still has the double shift feel?
Is this common? Has anyone else felt this. Hope trans is not going already?
Thanks in advance for any help
Scott
Old Nov 19, 2009 | 12:18 PM
NJMurvin's Avatar
Sounds like TC lockup. Should be firmer under load - but not too hard. I'm sure the trans experts here will chime in. Is it the same in T/H?
Old Nov 19, 2009 | 12:43 PM
ssandlin's Avatar
My 06 does exactly the same thing and has done it from the day I drove it off the dealer's lot, which was 82,000 miles ago.
Is it supposed to do that? I don't know.
Old Nov 19, 2009 | 01:01 PM
Green_Machine's Avatar
My '03 48re does it and I have only owned the truck a short time, but I kinda cringe each time it happens. It seems to be when I let off the juice and it happens to shift at the same time, it kinda stutters.
It's not a great feeling with the torque of the diesel it's amplified...
But it hasn't broken yet!
C
Old Nov 19, 2009 | 02:03 PM
pdogg's Avatar
mine did that when I got it at 42k miles.... I did a fluid change, and it helped a lot... now at 55k and it's smooth as silk...
Old Nov 19, 2009 | 02:16 PM
jimbo486's Avatar
that little half shift you feel is the TC locking up. it'll drop about 100RPM also.
Old Nov 19, 2009 | 02:19 PM
Ok guys, once again thanks for the help.
I did a complete fluid change as well maybe it will get better.
It does do it in T/H or not, once again not real hard but stiff for sure.
Sounds like it may be common thing. Oh well I will run it hard and see what happens.
Thanks again,
Scott
CTDCAL
Sep 27, 2003 03:22 PM
dansdad
Sep 6, 2003 09:00 PM
Sittenbull2
May 30, 2003 11:16 PM
Sittenbull2
May 15, 2003 04:15 AM
malibu
Feb 5, 2003 08:22 AM
