47 re gasket
I just installed mt DTT valve body and reused the factory gasket last weekend. No leaks so far. Do yourself a favor and install a drain plug while the pan is off. I wish I would have done it......
Yes the pan gasket is reuseable. I need to get off my lazy tail and change mine. First need to find out if the band adjustments are the same as for the 48RE.
What do you mean someone stole bandwidth?
pan gskt
yes mark the pan gskt on your trans is reusable. it should be a black plastic design with a built in oring style rubber all the way around the gskt. if you dont feel comfortable reusing it i can send you a new one with the cd manual i got for you. i will put the cd manual in the mail next week.
d12
d12
ted_pulliam
Jul 16, 2009 11:33 AM
jmccart
14
Jul 31, 2008 11:46 PM
wildchild97
Sep 25, 2007 02:44 PM
