#4 fuel line failure
I have had 3 break and to me the common issue was the loss of the tubing brace which allowed the tubing to vibrate and crack. Last time I replaced it, i loctited the machine bolt and nut. Mine is old blue style and got it from Cummins. If you have an old style, I recommend loctite the suckers and you should not lose the bracing components which starts the whole process. Injector tubes 1-3 &5-6 have 326,000 miles on them. #4 is the only that gave me grief.
Mine broke at 41500 mi. $200+ at dealer installed, said it was not covered. Looked like the original but was told made better. Now I check the fasteners every so often. I did buy a spare from Cummins, $26 and it looks like your pic. Hope I never need it.
Totally stock. I'll go with jerk. However on another visit they did replace the seat heater under extended warranty after I had added some foam and screwed up the wires.
Hi all. When this thing fails does it make a huge mess or does it start out small and get bigger? I noticed a small what looked like fuel stain on the driveway under my truck the other day between the firewall and the engine.
I ordered the new style #4 fuel line and have been carrying it as a spare. Now with the onset of winter and boredom, I believe I will install it and keep the old one as a spare. It would be much easier to do it in my garage than in a rest area on an Interstate somewhere!
Are there any instructions I should follow? My understanding is when the engine is off then all the pressure is bled off too. Is this correct??
In the threads I've read around here, lots of guys smell diesel and pull over. It has sprayed everywhere.
Wonder if the leak you're seeing is a coolant leak? But inspect it to be certain. If you suspect the #4 line replace it so you're not stranded. You ought to be smelling diesel too.
yes, I just replaced mine again for the second time in 6 months on my 07 dodge. Is there a fix?
IPDiesel
07-29-2015 09:57 PM
dodgetrucker75
03-17-2011 09:15 PM
b_hinote
03-19-2009 11:27 PM
