2nd notice today about recall issue!!
Today was the 2nd time i had gotten a letter from dodge about a recall with the shifter lever on my truck...says to take it back to dealer to fix the problem....says somtimes the park pos does not become fully engauged therefore truck sliding into reverse ???anybody???
https://www.dieseltruckresource.com/...ad.php?t=97010
And btw, DONT get it fixed unless you want the annoying horn to honk with the door open, truck running, in reverse(backing into a parking spot, lining up to a trailer, etc)
I always had the habbit of setting the parking brake when I exit a running vehicle(and non running manuals), just force of habit...
I am not having the TSB done, screw the horn honking with the door open, youd think they could come up with a better "fix" than that...
I agree with Stacked.
You DO NOT want this annoying "fix" done to your truck. If you ever have to back up with your door open, it will drive you insane.........so I hear.
Mine doesn't have it and never will.
Just get yourself in the habit of always applying the parking brake when exiting the truck......running or not.
I told them the last time I was in, DON'T do the flash.. and nothing has been said since... I haven't gotten any further recalls about this issue and will ignore them when I do...
Just snap the seat belt buckle into the lock and the horn will not sound with the door open while backing up. Or, visit a local breaker (junk yard) and cut the seat belt off to keep in the center console for the occasion when you need to jump out to see how close you are to the ball when hooking up.
Better yet, if you haven't had the "fix" completed, just don't have it done!
The seat belt fix does not work on the 04.5 and I have heard th 05 also. Save time and don't go to the junk yard, just pull the seat belt plug under the seat and put a wire jumper across the plug and the truck thinks the belt is installed all the time, no annoying bells and whistles when you start the truck.
eightball
10-18-2006 12:13 PM
SOhappy
10-17-2006 10:14 AM
guzzirider
02-19-2004 09:55 PM
