2007 5.9 Serpentine belt
I am trying to install a new drive belt. How in the Hell does this thing go on? I worked for 3 hours with no luck. Is there online illustrations out there anywhere. Every vehicle I've ever owned always had a diagram on the shroud but not this truck. What is the trick?
Thanks, racfan9
Thanks, racfan9
It does not go around the fan. I know it doesn't make much sense, but if you are starting by looping the belt over the fan it will never work.
Check this thread, https://www.dieseltruckresource.com/...l-t179647.html And a couple of other threads referenced within as well.
Hope this helps.
Hope this helps.
DodgeDiesel61
01-26-2019 07:45 PM
