2004 Dodge throwing this code P0251
Well I think I figured it out, it was a loose wire on the fca plug. I went out today and started her up, let it idle for about 5 minutes. I then reached down and gently took off the plastic plug on the fca, wow, she started shaking and stumbling. I did this to find out what it would run like if there was a short or break in the wire/connector. I pluged it back in and it started running fine. I then started moving and shaking the wire harness and wow, we now have a rodeo again, then she completely quit. I restarted it and it ran fine until I started moving the wires around the plug that goes to the fca and it went into round 3 of shaking and bucking, then it quit again. I got to lightly pulling on the wires that went into the plug and one of them almost fell out. The little prongs that hold the wire conector in the plug wasnt bent enough to hold itself in, I bent it a little and it works perfectlly. I shook the wires and it would not do it again. I REALLY hope this fixed it. I still have the code showing up cause I dont have a scanner to clear it yet. Hope this helps for someone else.
Back to morning brew . . .
Stevenc
Feb 27, 2005 06:48 PM
converteddzlr
Oct 25, 2004 01:40 PM
