2003- Ho? 4.10?
How do you tell if a 2003 Cummins is an HO or not? How can I tell what rear gears are in it?
Going to look at the truck after work and would like to be able to tell. |
Here's some reading I found:
2003 235 @ 2,700 460 @ 1,400 47RE Auto 8216 CARB: Catalyst 235 @ 2,700 460 @ 1,400 Five-speed manual 8224 CARB: Catalyst 250 @ 2,900 460 @ 1,400 47RE Auto 2624 Federal (no cat) 250 @ 2,900 460 @ 1,400 Five-speed manual 8223 Federal (no cat) 305 @ 2,900 555 @ 1,400 Six-speed manual 2998 Federal (no cat) 2003.5 235 @ 2,700 460 @ 1,400 47RE Auto 8410 CARB: Catalyst 235 @ 2,700 460 @ 1,400 Five-speed manual 8412 CARB: Catalyst 250 @ 2,900 460 @ 1,400 47RE Auto 8212 Federal (no cat) 250 @ 2,900 460 @ 1,400 Five-speed manual 8226 Federal (no cat) 305 @ 2,900 555 @ 1,400 Six-speed manual 8228 Federal (no cat) 305 @ 2,900 555 @ 1,400 48RE auto 8213 Federal (no cat) Basically it looks like in '03 (and '03 1/2) the HO was only available with the 48RE auto and the 6-speed manual. There will be a plaque on the drivers side valve cover on the engine that will tell you the power output. |
Check the eighth digit of the VIN. It will either be a "6" or a "C".
6 = Standard Output C = High Output |
It's a 6. So not HO and it has a 5 speed.
I called the dealer and found out it also has the 4.10 rear end. |
Originally Posted by fade94
(Post 2747247)
I was looking at that or the S-06.
BTW, I have looked on the Mads website and can't find anything about this new "POD" (Power On Demand) feature? |
had my 03 HO since new - if I remember right the only way you could get the HO was with the 6 spd manual so is a good indicator - I believe POD stuff is on the website but, you will be VERY happy with the Jr if you try it - LUV mine, think it is the best compared to the others I have tried on my truck! Good luck!
Originally Posted by alltimelow1
(Post 2747490)
Picked up the truck tonight. So far very happy with it. |
Engine output, transmission, possibly the smaller 10.5 rear end and different u-joints that I know of.
I have a 03 SO 5spd, smarty gave me two hundred dyno proven HP. . just something to think about.
now I am curious about my rear end gears. I run out of RPM about 106mph. |
Cool.
Truck came with exhaust and CAI. FASS will be going on soon and then I'll replace those bright ricer looking Autometer gauges with ISSPRO. Man they are bright. |
