2 micron spin-on filter with water separator
Old Nov 13, 2007 | 07:56 AM
AlCorr's Avatar
OK, I picket up a Baldwin Spin-on filter head FB1311 and a Baldwin, BF1212, 4 micron, spin on fuel filter with a water separator, at the heavy duty truck parts store. My question is; where can I get a 2 micron spin on filter with a water separator? Anyone have any comments?
Old Nov 13, 2007 | 08:46 AM
AlCorr's Avatar
I'm looking for a 2 micron spin-on fuel filter with water separator. If anyone has the Fleetguard numbers for one please let me know. Thank You.
Old Nov 13, 2007 | 10:32 AM
jkitterman's Avatar
You are a lot better off doing the water separation and 2 micron filtration in two steps.
Old Nov 13, 2007 | 10:45 AM
AlCorr's Avatar
Is this because?
Old Nov 13, 2007 | 12:03 PM
MikeyB's Avatar
Don't know of any 2 micron filters with a water separator. Setups like Airdog and FASS have both.
Why not just run a 10 micron in stock fuel filter canister with a remote 2 micron filter before the CP3.
MikeyB
Old Nov 13, 2007 | 12:05 PM
Blast Chamber's Avatar
Here's what I use....
http://www.perma-cool.com/Catalog/Cat_page26.html
Old Nov 13, 2007 | 12:46 PM
AlCorr's Avatar
MikeyB
This maybe the way I'll go, with a 2 micron spin-on filter in my remote/no water separator and a 4 micron in my stock canister filter/with water separator. Unless someone can tell me where to get a 2 micron /with water separator.
Old Nov 13, 2007 | 01:22 PM
tcr's Avatar
tcr
If you use the long 2 mic fuel filters(I use a 12-13" Wix 33674), all the water should stay in the fuel filter if it's down at the frame rail at a low point in the system.
Old Nov 13, 2007 | 01:47 PM
AlCorr's Avatar
Yes , it is on the frame rail. Thanks for the advise.
Old Nov 13, 2007 | 03:39 PM
C Schomer's Avatar
I kept the oem filter because it already has water seperator and indicator light. Craig
Old Nov 13, 2007 | 07:16 PM
Jeff in TD's Avatar
Since aftermarket 2 micron systems don't usually have a fuel heater, do they cause any issues with jelling/waxing up in the winter?
Old Nov 14, 2007 | 11:06 AM
AlCorr's Avatar
I,m not sure, good question, I always use a good winter additive all winter (Howes Lubricator).
Old Nov 14, 2007 | 05:30 PM
El Borrego's Avatar
El Borrego
I'm a little confused. Do you guys still run the OEM 10 micron fuel filter and are adding an additional 2 micron filter?
Old Nov 14, 2007 | 07:22 PM
johnh's Avatar
try this https://www.dieseltruckresource.com/...hp?photo=22534
Old Nov 14, 2007 | 08:15 PM
Correct. Most guys will put the 2-micron filter between the OEM 10-micron filter and the CP3 injection pump.
In my case, I run the PermaCool 2-micron filter/separator before the OEM filter. That's just the way it worked out on my custom system.
