118 Miles and no start???????
Old Oct 28, 2007 | 07:29 PM
BIGBEN2004's Avatar
A friend of mine just bought a new 4door long bed 4x4 auto. 5.9 Cummins
yesterday. It was the last 5.9 on the lot. Tonight he just called me on the
phone and asked why it wont start? He was at the local target in
the parking lot and went to start it and nothing. It would light up the dash
and had plenty of current from the batteries and when he would turn the key
nothing, not even a crank of the engine. He also tried to start in neutral and
then back in park and nothing. I told him to check fuses and start reading
the owners manual. He called me back about 5 minutes later and said while he
was looking at the owners manual he had the key in the run position and he
heard a click sound behind the dash and then the {PRND21} went blank for a
second or two and then came back on. He turned the switch and wala, it
started right up for him. I told him to have it checked out by the dealer
but he wanted to know if anyone on here has a answer for him. The truck
only has 118 miles on it so he is concerned on what it is. I told him to buy the
5.9 instead of the 6.7 so he wouldn't have any new problems that the new
trucks have been having but I didn't expect something like this to
happen. I told him like anything mass produced in the world their is
always a bad part sometimes and it will happen on any vehicle.
Old Oct 29, 2007 | 04:39 PM
BIGBEN2004's Avatar
I can't believe nobody has had this problem before? So far it hasn't happened again though and he has it set up to go in to the dealer soon to check it out. I will post if they say anything in case it happens to anyone else.
Old Oct 29, 2007 | 05:13 PM
coparam4x4's Avatar
Did he try to see if it threw any codes??
Cycle the key on and off 3 times ending with the key in the on position and you should see a code come up where the odometer is. If there isn't a code I think it will say "done".
Old Oct 29, 2007 | 05:59 PM
jballou's Avatar
Cycling the key will not give up the codes on a 06 and up truck. Gotta go to the dealer.
Old Oct 29, 2007 | 06:25 PM
Dale_K's Avatar
I don't think you're correct. I can get codes in my new 07 by cycling the key. I don't know what's wrong with the guy's truck though. Hope everything works out for him.
Old Oct 29, 2007 | 06:38 PM
MTC's Avatar
MTC
There are numerous threads about this problem all over this site. It happened to my buddies truck and it was the little yellow wire going to the starter that kept grounding out...and no start. We moved the wire from the metal bracket and no problems since.
Old Oct 29, 2007 | 08:51 PM
BIGBEN2004's Avatar
We tried it tonight and it did work but no codes. It just flashed with blank lines where the odometer normally is and then it said DONE. No codes I guess, we will try and find that yellow wire and give that a shot.
Old Oct 29, 2007 | 09:01 PM
coparam4x4's Avatar
Yes the 06's do work this way I have retrieved one code for trying to start my truck with a spare cut key (no chip).
BTW no it didn't start with the spare key(no chip).
Old Oct 29, 2007 | 10:34 PM
jetlife's Avatar
Wow! Thanks for the info. I pick up my new 07-5.9 tomorrow. My first Diesel. I've wanted one for years, finally decided to give up the gas truck. I can't wait to pick it up. Thanks to everyone for all the great info!!!
Old Nov 10, 2007 | 07:31 PM
BIGBEN2004's Avatar
Now my buddies new truck did another weird thing today. He was leaving my house and when he put his truck in reverse it began honking the horn and blinking the lights like he hit the panic button on the key. It did it every time even after he shut the truck off on restarted it. I told him to get it checked out by the dealer before I run it plowing snow this year. I would hate to have that happen at about 2:00am in a housing development. LOL
Old Nov 10, 2007 | 08:23 PM
Dodgezilla's Avatar
It may be the Sentry key not communicating with the truck's computer. I've seen that issue posted several times on 06s and 07s....
He may want to keep the second key with him just in case......
Old Nov 10, 2007 | 09:21 PM
duzdirt's Avatar
Just logged on to this site, but my wife has had this same problem.
What we did was to start pulling fuses one at a time , it may sound strange but fuse #11 Reset the something and everything worked fine.
Has happened twice now, got to get to the dealer soon.
Old Nov 10, 2007 | 09:41 PM
kelley15's Avatar
The horn honking thing is a safety feature. If door is open in reverse and brake peddle isn't pushed it will honk. Lovely feature huh?
Old Nov 11, 2007 | 08:59 AM
SSminnow's Avatar
Sounds like electrical/alarm type of problem.
Loose connection (battery/starter....?????)
Corrosion @ battery terminals????
Security key/new key????
Alarm, factory or aftermarket??????
Old Nov 11, 2007 | 12:07 PM
Sevir's Avatar
The first problem sounded like the sentry key (got to love those things, glad i dont have one)
The second problem is that safety feature, if you have your door open and something with the seat belt it will go off. (glad i dont have that one either)
boostedve
Nov 8, 2010 10:42 PM
Txwelder
Sep 27, 2007 07:48 PM
Timinva
24
Mar 24, 2007 11:17 AM
joelmopar12
Jan 23, 2006 11:00 AM
Hummin Cummins
Feb 11, 2003 12:14 PM
